Timing belt + water pump + ?
Is there anything else i should replace while changing the timing belt and water pump on my B18C1? I've heard there's a balancer belt as well, not sure though.
Would it be necessary to replace the timing belt with an aftermarket one like Toda or any other brand of higher quality? Or should i stick to the OEM belt? My mods consist of only bolt ons, I/H/E. I don't think i'll ever go any further than some minor cylinder head work like CTR/ITR cams and valve train.
This is also a good time to replace the cooling system hoses, at least the two big ones if not the little ones too. It's good preventive maintenance (rather than having them fail at an inconvenient time), the change interval is appropriately long, and you'll have some savings since you're flushing the coolant anyway as part of the water pump replacement.
Just did mine a couple months ago.
Timing belt
Water pump
Tensioner and spring
A/C, P/S, and alt belts
Front main seal
Valve cover gasket kit
Cam seal
All oem. The cheapest online place i could find was Bernardi Acura, and i looked everywhere. You can get some of the stuff a little cheaper from Majestic Honda, but they can't get some of the parts (e.g. timing belt)
Timing belt
Water pump
Front main seal
Cam seal
Timing belt
Water pump
Front main seal
Cam seal
Timing belt
Water pump
Front main seal
Cam seal
