Manual Transmission Oil ?
I was told you can use synthetic motor oil in a manual transmission. I cant remember which kind though. Has anyone use synthetic motor oil in the manual tranny before? If so what kind? thanks
in a pinch i'm sure it wouldn't hurt to mix MTF and 10w30, but you'll know exactly what you have if it's 100% of one or the other.
1grex: is there any diff. between honda MTF and acura MTF...? i would assume they're the same.
ATF doesn't belong in a manual trans... even if it's from honda!
Honda states that it is ok to use 10w-30 motor oil as a temporary replacement and it works fine. I ran mine (200,xxx mile tranny) with 10w-30 conventional motor oil for some time without any problems, I then switched to Royal Purple synthetic, it was horrible (syncro problems and leaks from the axle seals). I'm finally back to what I originally had, which is Honda MTF and it is by far the best from my experience.
Sounds like you're already sold, but I'll just echo the suggestion: 'Honda MTF!'
My car had std Xw-30W motor oil installed when I bought it.
This worked 'OK,' but I was surprised and very pleased when the MTF went in. The synchro clutches match speed much more smoothly (not that I abuse them), and the shift effort is greatly reduced.
I understand some of the aftermarket MTF is just as good.
The trick is finding a good brand at a price cheap enough to justify the hassle.
FWIW.
FWIW.
Alex_C
33
Oct 31, 2008 11:04 AM
