Transmission JACK--to Drop Engine
Old May 6, 2009 | 08:48 PM
mltv's Avatar
Default Transmission JACK--to Drop Engine
I looking over what others have done when removing the engine from the bottom, but none have really used a transmission jack or and engine adaptor to attache to the jack.
Based on the dimensions of the block, being nearly 14.5 inches tall from top of the block to the oil pan. (b18a1 the engine will have no head) There should not be any interference none what so ever. just to let you guys know I cant use a cherry picker, as I dont have enough room. Just wanted to see if anyone had used a similar method or dont something like it before.
Old May 6, 2009 | 08:53 PM
vladd's Avatar
Default Re: Transmission JACK--to Drop Engine
whats a transmission jack? why not just use a regular 'ol jack? that's what i did when putting in my integra motor from the bottom.
Old May 6, 2009 | 08:57 PM
mltv's Avatar
well I know its do able I would guess its be alot more stable with larger contact surface like the one in this link
http://www.denlorstools.com/home/dt1..._1200_lb..html
Old May 6, 2009 | 09:37 PM
vladd's Avatar
if you have a buddy helping you, you should be fine with a regular jack. the hardest part about taking out the engine from the bottom is getting the car high enough, not balancing the engine on the jack. i've put in a few engines from the bottom and always used the regular jack that we've got.
Old May 6, 2009 | 10:04 PM
mltv's Avatar
well with the head off the engine it needs to be as high as 24", that will provide plenty of clearance. with some heavy duty jack stands those with the base of 12x12 it should reach the height. But i guess you answered my question indirectly Thanks I will try to put some pic's using the transmission jack.
Old May 6, 2009 | 10:08 PM
vladd's Avatar
haha my jack doesn't go high enough so i'd stack wood blocks on top of it to raise the car high enough. i'd use random wheels and wood blocks to prop the car on. it's ghetto, but it works . but yeah, let us know if the tranny jack makes it easier or not.
funkified
Dec 7, 2006 11:51 PM
DevinW
Aug 28, 2002 09:02 AM
GettaluvR
Jun 27, 2002 11:14 AM
civic-cpe
Jun 7, 2002 05:55 PM
