a little problem !!!!!!!!!!??????????kbjkbjkbj
Old May 6, 2009 | 06:14 PM
EGR95's Avatar
Default a little problem !!!!!!!!!!??????????kbjkbjkbj
who knows how to install autometer gauges they are air and fuel ratio and the water temp. the water gauges has three wires and the air and fuel ratio has three as well, but the wire are colored one is blk, red, and pur. if any body knows thanks for your help.
Old May 6, 2009 | 06:20 PM
94EG8's Avatar
Seagull Management
Default Re: a little problem !!!!!!!!!!??????????kbjkbjkbj
Please use a more descriptive thread topic next time as seen here ---> https://honda-tech.com/forums/showthread.php?t=2407755
Old May 6, 2009 | 06:21 PM
z6hatchboy's Avatar
the the a/f the black is ground red power and purple (or whatever color) is signal. Take the signal to the o2 sensor signal on the ecu. For the water temp youll probably have to find someone to tap into with a "t" or something
Old May 6, 2009 | 06:43 PM
EGR95's Avatar
the signal... right so what wire do i need to cut if the O2 sensor has three wires?
Old May 6, 2009 | 06:44 PM
EGR95's Avatar
sorry bro.
Old May 6, 2009 | 06:51 PM
SubieDude's Avatar
This was a quick google search.
http://www.egauges.com/pdf/AutoMeter/837j.pdf
Old May 6, 2009 | 06:53 PM
EGR95's Avatar
i try that, but i couldnt find anything.
Old May 6, 2009 | 07:10 PM
SubieDude's Avatar
hmm well like i said. That took me about 10 seconds to find. Hope it helps you.
Old May 6, 2009 | 07:12 PM
EGR95's Avatar
wait i found it lol, but do u have for the water temp?
Old May 7, 2009 | 02:45 AM
SubieDude's Avatar
Try this one for the water temp.
http://www.egauges.com/pdf/AutoMeter/771d.pdf
hatchinprogress
Nov 2, 2004 01:52 PM
