93 Civic EX Coupe Axle Problems
I have 93 Civic automatic tranny and I need to know what axle I should use on the right side of the vehicle. I have D15B engine and that's the issue I cant figure out what part to use and my axle is badly damaged. Please help. ASAP.
Is that a JDM D15B or D15B7? Also, is the right side the passenger side or the driver side?
You have to figure out which transmission you have and then look for an axle for that transmission.
use any '92 - '00 D-series axle for whatever side you need, automatic and manual are all the same, the only thing that matters is if the car has ABS you need to use an ABS axle for the ABS to function, if its non ABS then it doesn't matter if you use an ABS or non ABS axle.
