GSR CLUSTER HELP..RESERCHED-Found NOTHING
Old May 6, 2009 | 01:06 PM
igorka_91's Avatar
Default GSR CLUSTER HELP..RESERCHED-Found NOTHING
Ok i serched and found nothing in the stikies.
I really didnt want to start a new thread..oh well.
What im looking for is a: DIY cluster bulbs die...or to make ure cluster glow red or what ever collor you want. All i found in the FAQs sections was. How to swap clusters for typeR ones........?
Someone plz send me the url....I remember seeing it about 3 months ago and cant find it..
thanks
OK I KINDA FOUND WHAT I WAS LOOKING FOR=https://honda-tech.com/forums/showthread.php?t=2087242 post #9
Old May 6, 2009 | 04:02 PM
igorka_91's Avatar
Default Re: GSR CLUSTER HELP..RESERCHED-Found NOTHING
Anyone.....im 100% shure theres a write up on how to do this...i jus cant find it.
Old May 6, 2009 | 04:08 PM
TunerN00b's Avatar
Use phillips screwdriver, remove console surround trim piece.
Remove cluster, also phillips screws if my memory serves.
Try not to drop screws behind cluster when removing.
Bulbs are in twist sockets, remove socket and swap bulb to colored bulb of choice.
Reinstall.
Sorry, I have no pics, but it really is a super simple procedure.
I used generic Pep Boys 194NA bulbs (3 total) to get an amber cluster.
Old May 6, 2009 | 05:18 PM
igorka_91's Avatar
Reinstall.
Thanks...I know how to remove the cluster and stuff... Im loking for the whole write up on how to do the hole cluster with out buying the bulbs. All u do i stick the bulbs into cardboard box and paint the other side with a couple of layers of this special paint.......?
There was an DIY a couple of months ago. I forgot the name of that tread....
Anyone with more imputt
Thanks again.
Old May 6, 2009 | 06:05 PM
Inaccurate's Avatar
double post
Old May 6, 2009 | 06:07 PM
Inaccurate's Avatar
http://www.team-integra.net/forum/di...TopicID=245297
its called led cluster retrofitted
http://www.rose-hulman.edu/~godwinmt...es/Page735.htm
theres another pic on that page
Old May 7, 2009 | 09:31 AM
igorka_91's Avatar
Originally Posted by Inaccurate
Thanks
Its still not what im looking for. The guy that did it stuck the light bulbs into carboard and painted them so they will glow red. Ok Just tell me what paint to use on the bulbs and ill do it myself.......Hopefully i wont mess up the cluster collor schemes.
Thanks guys. meanwhile ill keep on searching for that one post.
Old May 7, 2009 | 10:52 AM
TunerN00b's Avatar
I would go buy red bulbs, available at Pep Boys or Vatozone, long before trying to paint the stock ones. Paint fades and discolors over time due to the heat.
If you insist on painting, you just need to cover the base of the bulb. Pushing it into a sheet of cardboard would work. Use "stained glass" or equivalent paint.
Old May 7, 2009 | 10:56 AM
hmoobhero's Avatar
cant you just buy amber cluster light bulbs from honda? thats if you want it amber...
Old May 7, 2009 | 11:00 AM
igorka_91's Avatar
i already gott the chevy orange paint thats rated to 500* degrees.....im having a hard time taking the cluster out.
danomatic93
59
Aug 22, 2018 07:58 PM
Mires
Feb 23, 2004 07:56 PM
J337_UNIT
Apr 23, 2003 04:11 PM
RHGSR01
Dec 11, 2001 07:46 AM
Yyz
Aug 13, 2001 07:12 AM
