over heating?
Old May 6, 2009 | 12:19 PM
adammilad's Avatar
Default over heating?
hey guys i just rebuilt a d16y8 and i installed it into my hatch, and know when i turn it on it runs fine, but after i drove it around the block i noticed it was leaking coolant from somewere under the distributor and is leaking down the VIN and were it says d16y8, also when i took the oil cap off of the valve cover, smoke comes out of it. i have hondata and the water temp gets to about 200 degrees farenheit. i was wondering if anyone has had this problem before and what was there solution, i just want to make sure i didnt put anything on wrong.
Thanks for any help.
Old May 6, 2009 | 12:25 PM
forcefedferio's Avatar
Default Re: over heating?
check your thermostat/thermostat housing. Also check the upper hose, if you are using the stock spring clamp, ditch it for an adjustable hose clamp. The spring clamp is a better design, but just like any other part after so many years they tend to fail.
Old May 6, 2009 | 12:29 PM
adammilad's Avatar
do you know how hot it should get? what is the normal tempature after it warms up.
jonyi27
Dec 4, 2015 02:43 PM
FreshPurp
May 9, 2013 11:51 AM
Dzanjin
Engine Management and Tuning
23
Dec 30, 2012 03:26 PM
SIRIUS VTEC
12
Jun 13, 2010 01:09 PM
jvonb
Dec 2, 2005 03:15 PM
