how to tell between b16a2 (si) and b16a2 (sir)
Old May 6, 2009 | 11:30 AM
Kazan's Avatar
Default how to tell between b16a2 (si) and b16a2 (sir)
ok recently i purchased a b16a2 canadien SIR engine, my dad wasn't the happiest camper about the idea of me getting the engine so he started trying to badtrip my life and he asked me a question that really stuck in my head, now both SI and SIR motors are called b16a2 i think SI is USDM and SIR is canadien, how do I tell which is which? cuz my dad is laughing at me telling me the guy ****ed me over I got an SI instead of getting an SIR lol I have an evil dad I know evil but always helpfull :D
Old May 6, 2009 | 02:48 PM
4serioferio's Avatar
Default Re: how to tell between b16a2 (si) and b16a2 (sir)
B16a2 is just a2, not SiR.
SiR is B16a.
a2 is considered better anyway.
Old May 6, 2009 | 02:51 PM
trustdestruction's Avatar
lol
USDM Si = Canadian SiR
Same engine bro. No difference whatsoever.
Old May 6, 2009 | 03:21 PM
B18C5-EH2's Avatar
Former Moderator
Loved
A B16A2 from a 96-97 Del sol VTEC, 99-00 USDM Civic Si, and CDM SiR is the exact same engine performance-wise.
BTW before some lamer tells me:
"The Del Sol VTEC was a B16A3 dumbass!"
The B16A3 was in the 94-95 Del Sol VTEC and was OBD1, whilse the 96-97 Del Sol VTEC was the B16A2, OBD2.
Old May 6, 2009 | 03:23 PM
what i find weird is that the B16A3 came before the B16A2... what's up with that? (as long as what i've heard is true... the 5th digit meaning the version)
Old May 6, 2009 | 04:36 PM
eros18's Avatar
your dad might say "remember the time you got screwed with the engine?"
but seriously, im not a genius and all. I just do research myself.
USDM Si = CDM SiR
Trust those guys
Old May 8, 2009 | 09:46 AM
fc3srx729's Avatar
do a search noob, but they're the same...
Old May 8, 2009 | 12:21 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Originally Posted by Meyerman015
so now that you know this, you go and tell them....
That's got to be one of the worst stretches in order to get to post a "clever" forum pic.
Old May 8, 2009 | 01:03 PM
mortificationrock's Avatar
x2
My head hurts just trying to read that ****.
Old May 8, 2009 | 05:57 PM
amtheiceman's Avatar
ok.... ok.... and how did you pay for this engine american dollars or canadian dollars
because the engines are the same.....
sir canadian model
si american model
same engine----same car
i hope you didnt pay more for this engine.... thinkin is was better than the si model base... or then you really got........
Old May 8, 2009 | 08:11 PM
Murk 'EM's Avatar
SiR is B16a.
how is the a2 "considered" better then the B16a.. their exactaly the same but the B16a has higher comp pistons and i think higher duration lobes on the cams
Old May 8, 2009 | 08:33 PM
1LowSol's Avatar
B16A
Note: All JDM B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
  • VTEC
  • Found in:
    • 1988-1991 JDM Honda Integra RSi/XSi (DA6/DA8)
    • 1988-1991 JDM Honda CRX SiR (EF8)
    • 1988-1991 JDM Honda Civic SiR (EF9)
      • Displacement: 1,595 cc (97.3 cu in) 1.6 liter
      • Compression: 10.2:1
      • Bore: 81.0 mm (3.2 in)
      • Rod/stroke ratio: 77.4 mm
      • Power: 118 kW (160 PS; 158 bhp) @ 7600 rpm & 111 ft·lbf (150 N·m) @ 7000 rpm
      • Transmission: S1/J1/Y1
      • Redline: 8200 rpm
    • 1992-1996 JDM Honda CR-X del Sol SiR (EG2)
    • 1992-2000 JDM Honda Civic SiRII (EG6/EG9/EK4)
      • Compression: 10.4:1
      • Power: 130 kW (177 PS; 174 bhp) @ 7800 rpm & 116 ft·lbf (157 N·m) @ 7300 rpm
      • Valve Lift: IN 10.7 mm (0.42 in), EX 9.4 mm (0.37 in)
      • Inlet Valve Diamter: 33 by 2 millimetres (1.3 in × 0.079 in)
      • Transmission: S4C/Y21 (Some with LSD)
      • Redline: 8200 rpm
[edit] B16A2
Found in:
    • 1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
    • 1992-1997 Honda Civic del Sol EDM VTi (EG)
    • 1999-2000 Honda Civic USDM Si (EM1)
    • 1999-2000 Honda Civic CAN SIR EJ
      • Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
      • Power: 118 kW (160 PS; 158 bhp) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
      • Transmission: Y21 or S4C
Pretty much the same if you ask me.
Old May 8, 2009 | 08:54 PM
DualCamEJ's Avatar
SiR = same as JDM B16A 170hp compression 10.4
USDM SI = b16a2 160hp compression 10.2
Old May 8, 2009 | 08:55 PM
incorrect. He is talking about a Canadian SiR.
Old May 8, 2009 | 10:09 PM
Deetz's Avatar
Crazy Honda Guy
ALL B16A engines released in north america were 160hp...period!
In Japan, the 2nd gen B16A got an extra 10hp simply from .2 higher compression at 10.4:1 with the P30 pistons used in them.
Old May 8, 2009 | 10:21 PM
Murk 'EM's Avatar
yes that still doesnt explain why he said the a2 was "considered better" then the B16a SiR/SiR II
Old May 8, 2009 | 10:26 PM
Did it really need an explanation?
Here's the explanation:
He doesn't know what the hell he is talking about.
Deetz's Avatar
Crazy Honda Guy
it's not better, that's him just makin stuff up
Old May 8, 2009 | 10:30 PM
Murk 'EM's Avatar
thats all i wanted to see.. dont like people being wrong about **** they dont know about
Old May 9, 2009 | 05:41 AM
every1 here is just makin this so confusin..
READ THE THE QUESTION BEFORE YOU START POSTIN!!!
AGAIN...
1999-2000 Honda Civic USDM Si (EM1) HAS A B16A2
1999-2000 Honda Civic CAN SIR EJ HAS A B16A2
SAME IDENTICAL ENGINE
SAME IDENTICAL CAR!!!!
And to every1 here....NO not all b16 engines are the same
they come with different im,different ecus, different camsh,
The newer the engine year, the better the cam profile,
89-91 B16A cam lobe profiles are the weakest of the bunch.
and finally pistons...
There are 2 types of B16A pistons in the world. JDM and US. All US B16A engines are equipped with the PR3 B16A piston. Which yeilds a 10.2 compression ratio. All JDM B16A's are equipped with the P30 B16A piston which yeilds a 10.4 compression ratio. That's .2 more points over the US piston.
DO SOME RESEARCH YO ALL...
http://www.ff-squad.com/technet/
Old May 9, 2009 | 08:44 AM
eg_21's Avatar
SiR is B16a.
dude that's like saying
b18c1 > b18c jdm engines will always be better than any usdm engine period learn your facts before you open your mouth, i have personally owned d15b and d16z6 and the d15 is better
b16a2 and currently running a b16a in my hatch and b16a is way better
never had a usdm gsr, but i did have a b18c in my hatch and was whopping on usdm gsr and ls/vtec hatches out there so JDM > USDM.
Old May 9, 2009 | 08:54 AM
christian7750's Avatar
You tell the difference on the block. If its Sir II then it will Say B16A and if its A2 then it will say B16A2. And whoever says the USDM version is better your dumb.
Old Jan 2, 2010 | 09:27 AM
dnd.c.t.a.l2009's Avatar
New User
i have a civic 1992 vtec vti its idleing permantely a 6000rpm is it true that i need a new idle valve
Old Jan 2, 2010 | 09:32 AM
gibsanez's Avatar
I'm going to buy every single B16 left in existence and melt them so stupid threads like this don't come up anymore.
Old Jan 2, 2010 | 09:45 AM
00EckoSI's Avatar
way to thread jack...start your own post or do some research ur question had nothing to do with the original post....
