Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
ABS Light Is one
Old May 6, 2009 | 11:17 AM
Whatislove's Avatar
Default ABS Light Is one
My ABS light came on and wont turn off, it did turn off ones after I restarted the car but came back on soon again and has been on so far.
What could cause this?
Old May 6, 2009 | 11:43 AM
waaBAAH's Avatar
Default Re: ABS Light Is one
abs wheel sensor
speed sensor
and alternator
1. In the OBD-II connector, locate the Brown wire in the 9th pin position, and ground the wire. The ABS light should flash out the code to indicate the problem. If there are no codes, verify that the alternator is not overcharging.
2. To clear the ABS codes, cycle the ignition switch on and off 20 times or more. Then drive the vehicle faster than 7 miles per hour, and verify that the code will clear.
tell me the code stored.
is it just the abs light on?..or is srs on as well?
Old May 6, 2009 | 12:27 PM
Curiouz_G's Avatar
it could also be your ABS box might be fried or your wheel sensor is loose. ive experienced a loose abs sensor that did what you described.
Old May 6, 2009 | 01:13 PM
Whatislove's Avatar
Just abs, i'll stop by Autozone they do free readings.
I had my ABS come one like 3 times before after starting the car but would go away after a I restarted it, now its just on
Old May 11, 2009 | 05:42 AM
Whatislove's Avatar
I havnt had time to go to autozone to get a reading yet, but where would this abs wheel sensor be located? my abs light just turns on and off while im driving.
Old May 11, 2009 | 10:52 AM
batac_boy's Avatar
question, why it has to be the alternator?
Originally Posted by waaBAAH
abs wheel sensor
speed sensor
and alternator
Old May 17, 2009 | 11:56 AM
Whatislove's Avatar
Eh, light has been on solid, before it has been on and off. Now just on.
Just ABS, nothing else is one.
I need to find time and go to Autozone to get a free OBD reading done, but besides that anything I can check myself? I looked at the fuses and everything.
This wheel sensor, is that something accessible that can be inspected?
Old Jun 9, 2009 | 01:22 PM
Whatislove's Avatar
can anyone show me a diagram where I can locate the sensor?
Old Jun 12, 2009 | 11:31 AM
Whatislove's Avatar
anyone? I have no idea where the senor could be.
Old Jun 12, 2009 | 11:45 AM
Rob.C's Avatar
Directly mounted onto the knuckle
Old Jun 12, 2009 | 01:39 PM
waaBAAH's Avatar
it doesnt have to be altenator..
i was just listing things it could possibly be, and i copy and pasted exactly what napafix said to do.
if the abs system doesnt get correct voltage (overcharging or undercharging) then the abs system will shut down resulting in an abs light. a low charging and high charging vehicle can experience all sorts of electrical issues. it seems the civic is prone to false readings from teh altenator overcharging according to napafix.
check fuses first since you dotn have a scanner. check fuse 8 and 10 underhood.
fuse 8 is 20 amp, fuse 10 is 40amp.
from there it could be a couple of thigns.. but you do have one abs sensor for each wheel.
Old Jun 12, 2009 | 01:42 PM
SGolub's Avatar
Have you tried resetting it? If whatever caused it is no longer a problem, it should stay off after resetting.
Old Jun 12, 2009 | 04:12 PM
Whatislove's Avatar
Im not getting any OBD codes. I checked the fuses they are fine.
How do I reset it?
Old Jun 12, 2009 | 04:30 PM
waaBAAH's Avatar
How do I reset it?
i cant quote my own post..lol but try reading the second post and that is how you can clear them without a scanner
Old Jun 14, 2009 | 10:13 AM
Whatislove's Avatar
Yeah, I remember now. I didnt want to have to turn my car on and off 20 times on a 8 year old battery. Cant be got for something
Old Jun 14, 2009 | 11:51 AM
waaBAAH's Avatar
dont start your car 20 times.
"cycle" the ignition 20 times. (you know...the part where your dash lights come on is considered a "cycle").
Old Jun 14, 2009 | 01:53 PM
Whatislove's Avatar
Yup, I missread that. I'll give that a try
mr_munro
Mar 14, 2012 11:53 AM
siblue_gzer
Suspension & Brakes
10
Aug 13, 2007 04:49 PM
Shaun92lude
Dec 8, 2004 07:11 AM
Undercover_Skank
Mar 15, 2004 07:13 AM
Dirt
Jun 6, 2002 05:16 AM
