Clutch issue gsr help please
Old May 6, 2009 | 10:39 AM
SkaiWu's Avatar
Default Clutch issue gsr help please
this morning i wake up i turn my car on and try reversing out of my driveway.
i didnt stall but it goes - DUNK - - DUNK - everytime i let off the clutch cuz the engagement point is like ****ed up
like right now it looksl ike this
everything before the X is empty space, i can depress a good amount of my clutch while moving and it wont do ****
|...........................X............|
maybe i'm just trippin
but i got use to it quickly and seems to be way easier to shift and get into gears now
would this be considered stuck? burning clutch 24/7??
issues?
feed back ?
help please? this is weird **** and only happened this morning
forgot to mention that it has a new bearings
and the actual clutch itself is said to still be around 80%% by the shop who put the bearings in
Old May 7, 2009 | 10:20 AM
SkaiWu's Avatar
Default Re: Clutch issue gsr help please
bump
this **** is weird
i have too much empty clutch space
Old May 7, 2009 | 10:23 AM
jdm_bones's Avatar
What year is it? hydro or cable?
Old May 14, 2009 | 04:30 PM
SkaiWu's Avatar
95, and hydro, or it should be hydro anyways
ppl tell me its the clutch master leaking
apparently its leaking hard cuz i lost all my fluid when a shop checked it out
Old May 14, 2009 | 05:08 PM
Tegraracer90's Avatar
If you lost fluid, thats the first place i would start..check ur slave cylinder which is mounted right on the front of the tranny..see if its wet around there with fresh fluid...if not check ur mastercylinder which is located right next to your brake mastercylinder but smaller...check behind the clutch inside the car to see if u see any wet fluid or fluid dripping out back there...where ever you are losing fluid (master cylinder or slave) is what needs to be changed
fatfurious2
Sep 17, 2008 10:54 AM
ethereal2pt2
Nov 7, 2006 02:07 PM
djsire
Sep 7, 2005 04:14 PM
Hypertek99
Apr 8, 2005 12:56 PM
vjace
Jun 28, 2004 02:45 PM
