Suspension set up
Old May 6, 2009 | 12:00 AM
BlackBack's Avatar
New User
Default Suspension set up
My CRX Si will only be used to drive to and from school and obviously on the weekends. So I do not need super stiff springs and I also don't want the car to be scraping over speedbumps and all that good stuff. I'd just like a recommendation for a decent suspension setup that doesn't lower the car hugely, gives a good boost in handling performance, and isn't ridiculously expensive for a kid going to school (~$500 would be awesome, will pay up to $750 though) What are the thoughts on swaybars and what shocks/spring setups work well together? Many thanks
Old May 6, 2009 | 07:21 AM
dephtone's Avatar
Default Re: Suspension set up
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/%2A%2A-official-ef-suspension-thread%2A%2A-2533373/
Check out this suspension thread. K-sports are very nice full coilover system for ~650. 36 way adjustable. If you aren't looking to go that hardcore, check out the thread and see what others are running to give you an idea how their cars sit.
Old May 7, 2009 | 08:28 AM
1904wrencher's Avatar
If you are looking to do the work yourself , Then i would suggest Koni yellows, they have a lifetime warrenty. ( don't forget to send in the warrenty) and ground control. the Koni yellows are full adjustable from hard to soft. Their is also a adjustable on the shock to lower it if you want it to sit lower then usual. The ground controls are an adustable coilover. PEACE AND EVOL.
Old May 7, 2009 | 08:31 AM
mjfubar101's Avatar
Originally Posted by dephtone
https://honda-tech.com/forums/showthread.php?t=2533373
Why in the hell would you want 36 way adjustable for a DD, most people have no idea how to use them. Plus I havent heard the best of the Ksports in terms of the shock, a buddy just had to replace 2 because one leaked and the other was blown out after a year, Now when I say that it is his experiance and most wont have this problem, shocks are items that wear out and need to be replaced so keep that in mind.
A simple KYB would be a good shock to go with. 1904wrenchers on the right track
Oh yea this is a suspension question that will probably get moved to the suspension forum...
Old May 7, 2009 | 08:57 AM
BLU CIVIC's Avatar
Track Advocate
yeah i don't think the OP needs adjustable coiloers...KYB AGX and Neuspeed springs would be just fine...and i'd just keep the stock sway bars...
Old May 7, 2009 | 10:47 AM
SprintR's Avatar
Since when KYB is a good brand? I hurd lots of crap about KYB AGX. Bilstein ftw :D
Old May 7, 2009 | 10:53 AM
mjfubar101's Avatar
Never failed me or the 3 friends with them, but thats not a very good percentage of product just throwing ideas out there.
Old May 7, 2009 | 11:34 AM
sde780's Avatar
tein stech with some shocks. koni yellows are great from what ive read
user 93082343
15
Mar 21, 2009 08:23 PM
kevo1586
Nov 21, 2007 07:40 AM
Tad
Honda Civic (2001 - 2005)
Jun 15, 2006 10:33 PM
OppositeOfFast
Feb 2, 2003 10:48 AM
