Honda experts prepare to trip out
Old May 5, 2009 | 10:40 PM
HdmPowered's Avatar
Icon2 Honda experts prepare to trip out
I have a code 40?!?!?!
Motor is b18a1 stock gsr head
i went to swapshopracing(very helpful serious)
i brought in my car today and he fixed one problem with the idle
but still confused with the code 40
a mechanic there name bryan very helpful
he told me the problem might be somewhere in the engine harness
what do you guys think experts???
A challenge has been stowed upon you gifted ones in honda
help me please help me please
oo and my car is starting to jerk right after i release the clutch when i shift
do not kno what was happening it would jerk even if my foot was still
in the process of releasing the clutch
suggestions and answers would be greatly appreciated
Old May 5, 2009 | 10:43 PM
HdmPowered's Avatar
Default Re: Honda experts prepare to trip out
Help help
Old May 5, 2009 | 10:47 PM
HdmPowered's Avatar
No experts?
Old May 5, 2009 | 10:54 PM
Davus's Avatar
3 minute bump followed by 4 minute bump at near 2 AM, cool!
Cleaned idle air control valve, checked for gasket leaks? Code 40 is weird.
Old May 6, 2009 | 02:20 AM
MilanoCpe's Avatar
wait till morning for the experts to wake up..Bump for you. im stumped!
Old May 6, 2009 | 10:46 AM
HdmPowered's Avatar
help help
HdmPowered's Avatar
experts experts!!!!
Old May 6, 2009 | 10:48 AM
HdmPowered's Avatar
oo and i even swapped my iacv and no gasket leaks
Old May 6, 2009 | 11:02 AM
dbmora's Avatar
what ecu u running and what throttle body do u have on the car or do u have jumper on it
Old May 6, 2009 | 11:45 AM
HdmPowered's Avatar
i have a stock p28 ecu with a obd2a to obd1 jumper harness
i think its a stock gsr throttle body
Old May 6, 2009 | 11:49 AM
HdmPowered's Avatar
experts experts please bump if view
Old May 6, 2009 | 11:53 AM
HdmPowered's Avatar
ugh...
Old May 6, 2009 | 01:17 PM
Warhawk's Avatar
dude, no need to bump the thread every 3 minutes. you're gonna get banned if you keep that up...
Old May 6, 2009 | 02:07 PM
D16SiHatch's Avatar
yea really. starting a thread isn't like carrying on an aim conversation.
ok first off there is no code 40... there is a code 4 however. and a crankshaft position sensor being muffed up (which is inside your dizzy btw) could certainly cause something like what you're describing.
Old May 6, 2009 | 05:25 PM
HdmPowered's Avatar
i put my dizzy on a different car
no check engine light no nothing
dizzy not the problem
so im guessing nobody has had this problem
and sry bout the annoying bump
but this code 40 is annoying cause it dont exist
but my cluster is telling me it does
Old May 6, 2009 | 05:41 PM
TravisCadello's Avatar
I have read somewhere about this mystery code..... I just don't remember where and what about. daaam.
Old May 6, 2009 | 05:42 PM
You gotta take it to the Honda Dealership I believe that is what i read.
Old May 6, 2009 | 05:44 PM
theeboiivince's Avatar
i know im interupting but i have a problem too in my 99 accord i cant go past 5,000 rpm i think my intake mest up my car=[
Old May 6, 2009 | 05:47 PM
you car is in limp mode. check your check engine light and fix what ever code it is throwing.
Old May 6, 2009 | 05:56 PM
CivicSpoon's Avatar
Automatic ECU maybe?
Old May 6, 2009 | 06:01 PM
this is what i was gonna ask also.
Old May 6, 2009 | 06:09 PM
NVturbo's Avatar
O.G. triple O.G.
Whoever is "reading" the codes may not be reading it correctly. If the CEL light flashes four times in a quick manner, it's CODE 4....not CODE 40.
Old May 6, 2009 | 06:25 PM
z6hatchboy's Avatar
what is the car doing first off? It might be easier to diagnose by actual problems than a mystery code that could be a ecu problem or something
Old May 6, 2009 | 07:17 PM
he already said he swapped dizzys on another car and didn't pop up code 4 so his dizzy is good. and code 4 would be for the sensor in the dizzy.
Old May 6, 2009 | 08:07 PM
iluvmyef9's Avatar
its called a ghost code it when the a resistor on the ecu board is burnt or if the ecu is chipped and the tune is not sync it will through a ghost code try changing your ecu and see what that does
