Honda experts prepare to trip out
I have a code 40?!?!?!
Motor is b18a1 stock gsr head
i went to swapshopracing(very helpful serious)
i brought in my car today and he fixed one problem with the idle
but still confused with the code 40
a mechanic there name bryan very helpful
he told me the problem might be somewhere in the engine harness
what do you guys think experts???
A challenge has been stowed upon you gifted ones in honda
help me please help me please
oo and my car is starting to jerk right after i release the clutch when i shift
do not kno what was happening it would jerk even if my foot was still
in the process of releasing the clutch
suggestions and answers would be greatly appreciated
Re: Honda experts prepare to trip out
3 minute bump followed by 4 minute bump at near 2 AM, cool!
Cleaned idle air control valve, checked for gasket leaks? Code 40 is weird.
yea really. starting a thread isn't like carrying on an aim conversation.
ok first off there is no code 40... there is a code 4 however. and a crankshaft position sensor being muffed up (which is inside your dizzy btw) could certainly cause something like what you're describing.
i put my dizzy on a different car
no check engine light no nothing
dizzy not the problem
so im guessing nobody has had this problem
and sry bout the annoying bump
but this code 40 is annoying cause it dont exist
but my cluster is telling me it does
O.G. triple O.G.
Whoever is "reading" the codes may not be reading it correctly. If the CEL light flashes four times in a quick manner, it's CODE 4....not CODE 40.
what is the car doing first off? It might be easier to diagnose by actual problems than a mystery code that could be a ecu problem or something
he already said he swapped dizzys on another car and didn't pop up code 4 so his dizzy is good. and code 4 would be for the sensor in the dizzy.
its called a ghost code it when the a resistor on the ecu board is burnt or if the ecu is chipped and the tune is not sync it will through a ghost code try changing your ecu and see what that does
