95 eg 4 door ls swap info would be appreciated
i just bought a 1995 honda civic 4 door 5 speed,im gonna drop a ls swap into it but just want to make sure i have everything i need.....had a couple questions too
can i reuse the single cam harness with the ls motor as long as it is an obd1 as well?
where can i get swap motor mounts?
do i need swap axles to go from ls trans to eg spindles?
but yea so far i have an 94 obd1 ls engine and trans with axles mounts ecu and harness.....do i need anything else or am i set to start rippin away?its my first swap bein done by me and my buddy and wanted to do it right im a mechanic and all but just wanted to be sure
any info will help looking to start it saturday thanx
use everything you have there. Stock harness will work, the integra axles will bolt up, and as long as you have the rear "T" bracket from the integra and driver side motor mount from the integra you are good on mounts. You also should have the shift linkage from the integra as well.
Andrew14
20
Jun 27, 2010 06:22 PM
WingNutRacer98
Jan 16, 2003 05:05 AM
goodluck
