whole gauge cluster doesnt work...help!!
Old May 5, 2009 | 05:45 PM
boostfever's Avatar
Default whole gauge cluster doesnt work...help!!
my gauge cluster doesn't work and can't find out what is wrong with it. check all of the wiring and everything seems to be hook up.
Old May 5, 2009 | 07:17 PM
Blown90hatcH's Avatar
Default Re: whole gauge cluster doesnt work...help!!
What part about it doesn't work? Is it a 67 pinto or what? We need more details to be able to try and help.
Old May 6, 2009 | 04:43 AM
boostfever's Avatar
my speedometer needle, rpm needle, trip meter, gas and hot and cold needle. the only thing that's working are the lights on the cluster.
Old May 6, 2009 | 11:31 AM
dave181's Avatar
what year car what kinda car info like that will others to help you for example 95 civic dx
Old May 6, 2009 | 04:47 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car or go away. 94
Old May 6, 2009 | 05:13 PM
boostfever's Avatar
honda civic 99 dx
Old May 7, 2009 | 05:27 AM
fcm's Avatar
fcm
Old Fart
Have you checked the "METER "fuse, fuse 25 - 7.5A, [hot in run and start] in under dash fuse box.
don't just eyeball it test it or replace it with a known working, [or new] one.
You should also test for power at the fuse when ign. switch is in the run position.
If you have pulled your cluster for any reason before you had this problem, and fuse is good, pull the cluster and make sure the harness plug(s) is plugged in properly. 94
Old May 10, 2009 | 11:00 AM
boostfever's Avatar
there are about 10 of those 25 -7.5 fuse. which one am i suppose to replace? my sensor is connected. there are suppose to be only two wires with the green clips that connect to the back of the cluster right? one that connects to the top of the cluster and on the side.
Old May 10, 2009 | 12:15 PM
fcm's Avatar
fcm
Old Fart
There is only one fuse 25, [fuse number 25] it is a 7.5A fuse, it is in the under dash fuse box.
There are way more then two wire, but yes there are two "multi wire" plugs that plug into the back of the cluster. 94
Old May 11, 2009 | 06:43 AM
boostfever's Avatar
i have two green wire clips, one yellow wire and one orange wire clips but can't find where the orange one go to. i believe the yellow wire is for the air bag light.
Old May 11, 2009 | 06:52 AM
kyden's Avatar
orange is for abs, which you do not have.
bmxkills
May 30, 2015 06:13 AM
Perez_cb7
Jul 23, 2013 10:32 AM
wcoupe94
Mar 27, 2008 10:18 AM
.BigSexy
Mar 13, 2007 09:26 PM
JDM Vision
Jan 18, 2006 04:47 PM
