tachometer Problem!
Hey guys. Need some input on a problem that has been on going for 2 months now, and still have NO answer!
I purchased Smanager back in december for my 99 Civic coupe, with b16a2. I also purchased a OBD2b conversion harness to work with the p28 ecu. It was pre socketed at xenoncron and sent out brand new. THe harness was also.
After installation, i started the car with the laptop plugged in and i was recieving a tach signal to the cluster, and the laptop. My tuner went to hop in the car to go out for a quick street tune till i could get some dyno time. When he jumped in the car, he accidently touched his foot to the conversion harness, the car shut off, and when i went to restart it, noting happened. Dead. Jeff reached down and noticed one of the plugs wasnt fully plugged in, so he pushed it in, and i started the car with no problems, but notcied that my tach on the cluster had stopped working? Fiddling with some of the wiring, we got no were. We said **** it, and iv been driving the car with no tach since.
Once in a while, i get a little curious and pissed off and try to attempt to figure out the problem. So far, I have replaced the cluster, hard wired the tach to the tach test wire in the engine bay, check the IGN fuse,(#9 15amp) and am 100% garentee that it is not the distributor as the ECU is still receiving a tach signal.
here is where things become wacky. Before i sold my Stock ECU i put it back in the car, and the tach works!!!! weird eh? I checked over the conversion harness 10 times now, finding nothjing wrong with it at all. and also used a different conversion harness that works in my buddys car.
Im stumped, got no idea were to go from here.
Any help is apprechiated! Thank you!!!!
McNeil!
McNeil!
Care to elaberate? I actually believe my problem is my obd2b ecu supplied the tach signal instead of the distributor like OBD1 cars and now that I am running a OBD1 ecu I need to run a wire from the spare tab on the ignitor to the factory ecu harness terminal "A" pin #19 (engine pulse speed) to get the tach working again. I have not confirmed this but I think this is what I'm concluding from my studies.
firejackal
13
Oct 28, 2015 03:02 PM
