idle problem
Old May 5, 2009 | 03:54 PM
ilovemyh22's Avatar
Default idle problem
i have a 99 em1 with a b20 swap and it has a horrible idle problem it goes from 1000 to 3000 rpms can anyone help me with this problem
Old May 5, 2009 | 04:10 PM
EGR95's Avatar
Default Re: idle problem
i have the same problem, but my revs 1000 to 2000 i think its the vac and i did my b16a swap this weekend.
Old May 5, 2009 | 08:57 PM
ilovemyh22's Avatar
im not sure wat it is i think its missing the idle screw and i have no idea y
Old May 5, 2009 | 09:25 PM
ilovemyh22's Avatar
bump want to figure this out car sounds like **** at idle
Old May 6, 2009 | 11:15 AM
EGR95's Avatar
try checking the distur.... or the throttle...?
Old May 6, 2009 | 11:51 AM
4cyl707's Avatar
check vacuum lines ( or places could leak), idle air control valve, and the throttle body. I had the same problem with the gsr in my hatch. It idled at 1000-3500 rpm when cold and 1000-2300 when warm with no check engine light. The bottom portion of my throttle body where the coolant runs through has a housing with a float inside of it. When I took it apart The float inside rattled around loosely when I shook it. The housing to the metering device is plastic and it is threaded and some how it back it self off. I threaded back in as much as i could with a flat head. I put it back together and now it idles normal.
Heres a pic of what im talking about
Old May 6, 2009 | 12:23 PM
EGR95's Avatar
so thats the problem. do i need to rebuilt it?
Old May 6, 2009 | 12:54 PM
variable's Avatar
https://honda-tech.com/forums/showth...ht=idle+thread
<---End all Idle thread
philep_cb7_91
Feb 21, 2010 11:28 AM
gutted-dx
Dec 18, 2005 09:08 PM
R. Mack
Jun 1, 2005 07:55 PM
del soler
Sep 10, 2004 02:06 PM
wolf3007
Mar 26, 2004 05:06 AM
