need help asap. viper 5900 tach wire mess up dizzy?
Old May 5, 2009 | 02:55 PM
solsi2000's Avatar
Default need help asap. viper 5900 tach wire mess up dizzy?
hey guys will wiring the tach wire for the remote start mess up the dizzy? how would i bypass it? thanks
Old May 5, 2009 | 04:27 PM
fcm's Avatar
fcm
Old Fart
Default Re: need help asap. viper 5900 tach wire mess up dizzy?
It will not.
What is the MM&Y of your car? 94
Old May 5, 2009 | 04:50 PM
solsi2000's Avatar
93 del sol s model. what would be the best way to find the blue wire? some say it is the one by the dizzy others say its on the driver side firewall (would be best in my opinion). Reason why i posted this is because someone said that they experienced a dizzy blow up bc of this. i lol'd. and is there a way to have the car not start when it is in gear? thanks for the reply.
Old May 5, 2009 | 09:46 PM
solsi2000's Avatar
up
Old May 6, 2009 | 05:54 AM
fcm's Avatar
fcm
Old Fart
On a 93 Del Sol the blue lead is in a 2pin plug near the distributor.
Again, it can not harm the distributor.
For remote start on cars with fuel injectors, the signal is much better at the injector, connect the remote starts tach wire to the wire on the injector, [any injector] that is a different color on each injector.
You are taking a big chance on installing a remote start for automatic transmission only, on your standard transmission car.
You need one of these...
http://www.hifisoundconnection.com/S...id/0/SFV/30046 it will prevent the car from remotely starting in gear.
DEI also has something like it but more expensive. 94
ali954
Sep 21, 2009 12:10 PM
Psyke
Aug 29, 2005 05:11 AM
delslowh23
Sep 12, 2004 04:34 PM
huffer427
Jul 9, 2004 05:30 PM
