definitions please
Old May 5, 2009 | 02:31 PM
littledude56's Avatar
Default definitions please
I don't consider myself a noob but on forums like this when people use shorthand style typing sometimes I don't understand what they mean. like the 3 letter abbreviations
ex. lca= lower control arm and cel= check engine light. along those lines
definitions of any of these types of abbreviations would be appreciated
thanks in advance
Old May 5, 2009 | 04:53 PM
stevenDAtegra's Avatar
Default Re: definitions please
There are quite a few but some I remember off the top of my head are. a lot of them you can assume from the letters and the topic
VC= Valve Cover
HG=Head Gasket
Dizzy= Distributor
VSS= Vehicle Speed Sensor
FC- Flux Capacitator
IM= Intake MAnifold
Old May 5, 2009 | 06:04 PM
thanks for those, I do try and assume what they are but alot of it is me not knowing the part name or the full part name so what I try to think it is doesn't make sense
Old May 5, 2009 | 06:12 PM
KWayRacing's Avatar
Here are just a few I can think of...
TDC Top Dead Center
BDCBottom Dead Center
BTDC Before Top Dead Center
CC Cubic Centimeter
L Liter
mm Millimeter
EWH Engine wire harness
I/M Intake manifold
E/M Exhauust Manifold
WG Wastegate
BOV Blow Off Valve
IC Intercooler
DP DownPipe
SS Stainless Steel
P/S Power Steering
A/C Air Conditioning
AT Automatic Transmission
MT Manual Transmission
ABS Antilock Braking System
SRS Supplemental Restraint System
ECT Engine CoolantTemperature
TPS Throttle Position Sensor
MAP MAnifold Absolute Pressure
IAT Intake Air Temperature
VTEC Variable Valve Timing with Electronic Control
EGT Exhaust Gas Temperature
EGR Exhaust Gas Recirculate
PCV Positive Crankcase Ventilation-----IT IS NOT PVC like plumbing supplies
ECM Engine Control Module- only controls the engine
PCM Powertrain Control Module- Controls Engine and Transmission
OBD On Board Diagnostics Vresions 0,1,2,2a
DTC Diagnostic Trouble Code
ICM Ignition Control Module AKA Igniter
IACV Idle Air Control Valve
EACV Electronic Air Control Valve- functions same as above
DVOM Digital VOlt Ohm Meter
12V Battery voltage
+ Positive voltage
- Ground
IGN Ignition
MIG Metal Inert Gas
TIG Tungsten Inert Gas
POS Positive or Piece of Sh*t
Neg Negative
Good Luck Hope This Helps
Old May 5, 2009 | 07:17 PM
Blown90hatcH's Avatar
My .02 for now....I am tired...
COP = Coil on Plug
AL = Aluminum
Hella = California native stuck in the old school
TCU = Transmission control unit
TCM = Transmission control module
T1 = T1 race development
VSS = Is actually Vehicle Speed Sensor...someone above posted variable speed sensor.
I/H/E = Intake manifold, Header, Exhaust
Old May 5, 2009 | 07:23 PM
My bad lol
Old May 5, 2009 | 07:26 PM
Here is a list I found with just about everything
Honda abbreviations
A/C = Air Conditioning
A/F = Air/Fuel Ratio
A/T = Automatic Transmission or Transaxle
ABS = Antilock Braking System
ABSV = Air Bypass Solenoid Valve
AC = Alternating Current
ACTS = Air Charge Temperature Sensor
AFC = Air Flow Control
AFM = Air Flow Meter
AFS = Air Flow Sensor
ALCL = Assembly Line Communications Link
ALDL = Assembly Line Data Link
APS = Absolute Pressure Sensor
APS = Atmospheric Pressure Sensor
ASDM = Airbag System Diagnostic Module
ATDC = After Top Dead Centre
ATF = Automatic Transmission Fluid
ATS = Air Temperature Sensor
AWD = All Wheel Drive
B+ = Battery Positive Voltage
BARO = Barometric Pressure
BAT = Battery
BCM = Body Control Module
BHP = Brake Horse Power
BMAP = Barometric/Manifold Absolute Pressure Sensor
BPS = Back pressure Sensor
BPT = Back Pressure Transducer
BTDC = Before Top Dead Center
Btu = British Thermal Units
C = Celsius
C3I = Computer Controlled Coil Ignition
CALPAK = Calibration Pack
CAN = Controller Area Network
CANP = Canister Purge Solenoid Valve
CAS = Crank Angle Sensor
CC = Cubic Centimetres
CDI = Capacitor Discharge Ignition
CEAB = Cold Engine Air Bleed
CECU = Central Electronic Control Unit
CER = Cold Enrichment Rod
CESS = Cold Engine Sensor Switch
CFI = Central Fuel Injection
CFI = Continuous Fuel Injection
cfm = Cubic Feet Per Minute
CID = cylinder identification sensor
CID = Cubic Inch Displacement
CIS = Continuous Injection System
CKP = Crankshaft Position Sensor
CMP = Camshaft Position Sensor
CO = Carbon Monoxide
CO2 = Carbon Dioxide
COP = Coil On Plug ignition
CPI = Central Port Injection
CPU = Central Processing Unit
CSSA = Cold Start Spark Advance
CSSH = Cold Start Spark Hold
CTS = Coolant Temperature Sensor
CTVS = Choke Thermal Vacuum Switch
CVR = Control Vacuum Regulator
dB = Decibels
DC = Direct Current
DEFI = Digital Electronic Fuel Injection
DFS = Deceleration Fuel Shutoff
DIS = Distributorless Ignition System
DIS = Direct Ignition System
DLC = Data Link Connector
DOHC = Double OverHead Camshaft
DPF = Diesel Particulate Filter
DTC = Diagnostic Trouble Code
DVOM = Digital Volt Ohm Meter
E2PROM = Electrically Erasable Programmable Read Only Memory
EACV = Electronic Air Control Valve
EBCM = Electronic Brake Control Module
EBM = Electronic Body Module
ECA = Electronic Control Assembly
ECM = Engine Control Module
ECT = Engine Coolant Temperature
ECU = Electronic Control Unit
EDIS = Electronic Distributorless Ignition System
EEPROM = Electronically Erasable Programmable Read Only Memory
E2PROM = Electronically Erasable Programmable Read Only Memory
EFC = Electronic Fuel Control
EFCA = Electronic Fuel Control Assembly
EFI = Electronic Fuel Injection
EGO = Exhaust Gas Oxygen Sensor
EGR = Exhaust Gas Recirculation
EGRPS = EGR Valve Position Sensor
EGRT = EGR Temperature
EI = Electronic Ignition
EMI = Electromagnetic Interference
EMR = Electronic Module Retard
EOS = Exhaust Oxygen Sensor
EOBD = European Onboard Diagnostics
EPOS = EGR Valve Position Sensor
EPROM = Erasable Programmable Read Only Memory (chip)
ESC = Electronic Spark Control
EST = Electronic Spark Timing
EVAP = Evaporative Emission System
EVP = EGR Valve Position
F = Fahrenheit
FBC = Feedback Carburetor System
FBCA = Feedback Carburetor Actuator
FCS = Fuel Control Solenoid
FDC = Fuel Deceleration Valve
FI = Fuel Injection
FLS = Fluid Level Sensor
ft.lb. = Foot Pound
FWD = Front-Wheel Drive
GAL = Gallon
GDI = Gasoline Direct Injection
GEN = Generator
GND = Ground
GPM = Grams Per Mile
GPS = Global Positioning System
GVW = Gross Vehicle Weight
H20 = Water
HC = Hydrocarbon
HEGO = Heated Exhaust Gas Oxygen Sensor
HEI = High Energy Ignition
Hg = Mercury
HO2S = Heated Oxygen Sensor
hp = Horsepower
HT = High Tension
IAC = Idle Air Control
IAT = Intake Air Temperature
IATS = Intake Air Temperature Sensor
IC = Integrated Circuit
ICM = Ignition Control Module
ICS = Idle Control Solenoid
ID = Inside Diameter
IFI = Indirect Fuel Injection
IGN = Ignition
ISC = Idle Speed Control
ISO = International Standards Organization
ITCS = Ignition Timing Control System
ITS = Idle Tracking Switch
JAS = Jet Air System
kHz = Kilohertz
Km = Kilometres
KOEC = "Key On, Engine Cranking"
KOEO = "Key On, Engine Off"
KOER = "Key On, Engine Running"
kPa = Kilopascals
KS = Knock Sensor
KV = Kilovolts
L = Litres
lb. ft. = Pound Feet
LCD = Liquid Crystal Display
LED = Light Emitting Diode
LHD = Left-Hand Drive
LTFT = Long Term Fuel Trim
LWB = Long Wheel-Base
MAF = Mass Air Flow
MAP = Manifold Absolute Pressure
MAT = Manifold Air Temperature
MCS = Mixture Control Solenoid
MCT = Manifold Charge Temperature
MFI = Multi Port Fuel Injection
MIL = Malfunction Indicator Light
mm = Millimetres
MPFI = Multi Point Fuel Injection
MPG = Miles Per Gallon
MPH = Miles Per Hour
MPI = Multi Port Injection
MPV = Multi-Purpose Vehicle
ms = Millisecond
mV = Millivolts
Nm = Newton Metres
NOX = Oxides of Nitrogen
NVRAM = Nonvolatile Random Access Memory
O2 = Oxygen
O2S = Oxygen Sensor
OBD = Onboard Diagnostics
OBD I = Onboard Diagnostics One
OBD II = Onboard Diagnostics Two
OD = Outside Diameter
OE = Original Equipment
OEM = Original Equipment Manufacturer
OHC = OverHead Camshaft
OHV = OverHead Valve
OS = Oxygen Sensor
P/B = Power Bakes
P/N = Part Number
PA = Pressure Air
PAIR = Pulsed Secondary Air Injection
PAS = Power-Assisted Steering
PCM = Powertrain Control Module
PCV = Positive Crankcase Ventilation
PECV = Power Enrichment Control Valve
PFI = Port Fuel Injection
PID = Parameter ID
PIP = Profile ignition pickup
PNP = Park/Neutral Switch
PPM = Parts Per Million
PROM = Program Read Only Memory (chip)
PS = Power Steering
PSI = Pounds Per Square Inch
PSP = Power Steering Pressure
pt. = Pint
PTC = Pending Trouble Code
PTC = Positive temperature coefficient
PWR = Power to Weight Ratio
RAM = Random Access Memory
RFI = Radio Frequency Interference
RHD = Right-Hand Drive
ROM = Read Only Memory
RON = Rated Octane Number
RPM = Revolutions Per Minute
RWD = Rear-Wheel Drive
SC = Supercharged
SEFI = Sequential Electronic Fuel Injection
SES = Service Engine Soon (light)
SFI = Sequential Fuel Injection
SIPS = Side Impact Protection System
SOHC = Single Over Head Camshaft
SRS = Secondary Restraint System
SRS = Supplemental Restraint System (air bag)
SRT = System Readiness Test
SS = Speed Sensor
SSI = Solid State Ignition
STFT = Short Term Fuel Trim
SWB = Short Wheel-Base
TACH = Tachometer
TB = Throttle Body
TBI = Throttle Body Injection
TC = Turbocharged
TCC = Torque Converter Clutch
TCM = Transmission or Transaxle Control Module
TCS = Traction control solenoid (SAAB 9000)
TD = Turbo Diesel
TDC = Top Dead Center
TDI = Turbo Direct Injection (A turbo charged direct injected diesel engine)
TIV = Thermactor Idle Vacuum Valve
TKS = Throttle Kicker Solenoid
A/C = Air Conditioning http://www.x431ltd.co.uk/Abbhonda.html
5 of 5 17/10/07 21:39
TPI = Tuned Port Injection
TPP = Throttle Position Potentiometer
TPS = Throttle Position Sensor
TPT = Throttle Position Transducer
TSP = Throttle Solenoid Positioner
TV = Throttle Valve
TVS = Thermal Vacuum Switch
TWC = Three Way Catalyst
TWC+OC = Three Way + Oxidation Catalytic Converter
V V C = Variable Valve Control
V V T = Variable Valve Timing
WOT = Wide Open Throttle
Old May 5, 2009 | 07:31 PM
jhammond_82's Avatar
Reject Papi
thats a list right there! ^
Old May 5, 2009 | 07:33 PM
Yeah it is, seems like if it has 2 or more words everyone wants to abbreviate lol.
The site with that list is right here
http://www.x431ltd.co.uk/website/honda.pdf
BongoBennie
Jan 5, 2018 02:33 PM
vj30
Honda CR-V & Element
Aug 31, 2015 05:47 PM
infulleffect
Apr 13, 2006 08:15 PM
r1de4life
Jan 4, 2006 09:05 PM
