headgasket shopping
Old May 5, 2009 | 09:43 AM
GSE980's Avatar
Post headgasket shopping
were can I get a headgasket for a b18c1 .5mm over
Old May 5, 2009 | 09:49 AM
boost'd_crx's Avatar
Default Re: headgasket shopping
81 & 81.5 use the same gasket. you can use stock or aftermarket
Old May 5, 2009 | 01:17 PM
GSE980's Avatar
hell yeah what else do I need for a headgasket change
cam seals...
I have new arp stud in the head now do I need to replace these as well the engine doesnt even have 10k on it yet
Old May 5, 2009 | 01:47 PM
twentyhurtz's Avatar
cometic gaskets..
Old May 5, 2009 | 03:32 PM
GSE980's Avatar
what about them whats the differance
Old May 5, 2009 | 04:51 PM
stevenDAtegra's Avatar
If you wanna be safe replace all seals from things you took off
*Intake Manifold Gasket
*Exhaust Gasket
*Cam Seals
*Valve Seals if you want
*Vtec Solenoid Gasket
Just some things you could do
Old May 6, 2009 | 06:00 AM
GSE980's Avatar
any write ups online on how to do this.
Old May 6, 2009 | 06:14 AM
It's all really easy but there are probably write ups.
Do you have a haynes or helms manual? For getting the head off you just take off the intake manifold(possible to leave it on but it's harder), take off valve cover, loosen timing belt tensioner, slide belt over, take cams out and then remove the headbolts securing the head. There is an order you have loosen the bolts though which is from the outer headbolts towards the center. When you torque it down, torque from the center and out and this will make sure your head doesn't warp.
Old May 6, 2009 | 07:49 AM
GSE980's Avatar
i need to pick up a haynes manual then... I just afraid of taking the cams out be cause I dont wanna **** up the timing with my turbo cuz im sure 1 degree off can cause a catastophic failure
deerman2701
Feb 1, 2013 05:33 AM
shorejdm5
Apr 28, 2008 09:57 AM
DCf4i
11
Jan 7, 2008 01:44 PM
92integraVTECgsr
Feb 19, 2005 05:52 PM
bigmike
Apr 10, 2003 11:13 PM
