Callos Front End- What are you guys doing for Tow Hooks?
Old May 5, 2009 | 08:45 AM
Boner_Ben's Avatar
Default Callos Front End- What are you guys doing for Tow Hooks?
In the event of a parts breakage that requires the track officials to pull your car, what are you guys with Callos front ends doing? The tow hooks on my traction bar hang way above my front end so pull it by them is sure to damage the front end. Just wanted to see what everyone else has done.
Old May 5, 2009 | 08:47 AM
rota92
Guest
Posts: n/a
Default Re: Callos Front End- What are you guys doing for Tow Hooks?
I did a cool one that came off some holes in the front of the car and had a ball lock pin to hold the hook in so it could come on and off with the tow strap.
Oh, I do know this may not help your problem specifically but it may spark some ideas.
Old May 5, 2009 | 08:51 AM
sgnlab's Avatar
I just make sure I dont break! no really though it has been on my mind Rots thats a good idea!
Old May 5, 2009 | 08:52 AM
95integraLS003's Avatar
Ryans worked really well for the season, i was the one hooking and unhooking that thing and it made things super easy..
Well with the Callos 3pc front end ryans idea can be used it would just have to be modified to fit.
Depends on the setup, you would have to see what areas you can connect something to that can you can attach a mount.
Lets see other ideas!
Old May 5, 2009 | 09:12 AM
98exn20's Avatar
check this thread. pretty neat idea for front tow hook.
https://honda-tech.com/forums/showth...6#post38063846
Old May 5, 2009 | 09:56 AM
rota92
Guest
Posts: n/a
Or if you guys wanted to, do it HR style and come out of the hood/cowl or top of the A-pillar with a Ball lock pin.
Old May 5, 2009 | 09:57 AM
underpressure02's Avatar
I have been using one of rota's tow hooks and it worked great but not sure how to use it with the new front end.
Old May 5, 2009 | 10:08 AM
1992Si's Avatar
Can you attach the cup for Ryan's hook long the bottom of the front radiator support ?
It's less then 3/4" thick.
Another thought was put it on top of the radiator support and just open the hood, plug in the tow hook, when it needed to be towed.
You could weld a receiver bushing into the support.
Old May 5, 2009 | 10:12 AM
Boner_Ben's Avatar
I dont trust my core support for pulling the car. Definitly need something that attaches to the traction bar or something hot rod style. Just want to see what others have done already.
Old May 5, 2009 | 10:20 AM
I agree with you on that. The plate rota made for that mount it pretty thick steel and it bolts in three places and that actually started bending the metal on the car from being towed.
Old May 5, 2009 | 10:22 AM
K20Ahondas's Avatar
we still use the stock tow hook to pull the car. ours hangs low enough.
Old May 5, 2009 | 10:25 AM
Turbo-charged's Avatar
im sure we can just make something when you bring the car down ben
Old May 5, 2009 | 10:27 AM
callosracing's Avatar
Do it how some of the hot rods cars did it. We actually drilled the upper corner of the roof and attached the tow hook assy to the rollcage. I think we got the part from jerrybickel.com
search tow hook on their site and it will come up.
Old May 5, 2009 | 12:01 PM
htx_jr.95eg's Avatar
i just drive the car lol
Old May 5, 2009 | 01:15 PM
22_42r_eg's Avatar
[QUOTE=htx_jr.95eg;38421262]i just drive the car lol [/QUOTE
yeahhh since you dont have to fix it punk... i do!!!
Old May 5, 2009 | 01:20 PM
rota92
Guest
Posts: n/a
Yea you can get something like that not only from Bickel but Quartermax, VP etc. all of them their own style. Some are cooler than others but it's all the same concept.
Old May 5, 2009 | 11:41 PM
V-SPEC 1's Avatar
do you happen to have some pics of that setup? Thanks/salamat.
Old May 6, 2009 | 01:27 AM
DaveF's Avatar
Vanishing Point Racecars Tow hook kit
http://www.vpracecars.com/productView.asp?productID=532
these kits use a quick pin and a specially machined reciever for it, so it does not "pop out" when getting tugged on.
Old May 6, 2009 | 04:11 AM
redzcstandardhatch's Avatar
something different
why not do a cloth one that hangs out the front bumper like TONS of roadrace guys do?
Old May 6, 2009 | 07:03 AM
rota92
Guest
Posts: n/a
Cloth isn't drag racer approved Plus, when you say cloth tow hook to a drag racer you'll have all the idiots tying T-shirts to their cars.
I'll be using the Vanishing Point setup on my car, it's super cheap
Old May 6, 2009 | 07:16 AM
turbotypeR@SPEC's Avatar
25 Year Member
i use the traction bar plates that bolt between the frame rails
Old May 26, 2009 | 06:53 PM
RICE POLICE SIP's Avatar
how is it mounted?
foxjaeger
Mar 12, 2009 09:31 AM
rota power
Dec 10, 2005 08:48 PM
4piston
Nov 11, 2004 04:14 PM
