Flushing entire brake system....
Old Aug 17, 2002 | 05:44 AM
SloCivicHMM's Avatar
Default Flushing entire brake system....
My brake fluid is all brown and ****...and I want to change it to synthetic stuff, but how do I get ALL of the old stuff out???
I'm a newbie when it come to messing with y car...so help a learning brother out!! thanks..
92 EG Hatch with ZC swap....
Old Aug 17, 2002 | 05:47 AM
you2envious's Avatar
Default Re: Flushing entire brake system.... (SlowCivicHmm)
When I flushed a friends 300ZX (Nightmare by the way) . We kept putting new fluid in (much like bleeding brakes) . only we kept bleeding the brakes till the new fluid was coming out of each bleeder on each wheel . HOpe that was some help . Takes time too .
Old Aug 17, 2002 | 05:53 AM
Default Re: Flushing entire brake system.... (you2envious)
me and my friend tiff tried that yesterday...took for ever and it kept coming out brown......I guess I can try that **** again..but ****...haha
NE one else...thanks bro...
Old Aug 17, 2002 | 07:06 AM
migs's Avatar
You can take it to any modernized automotive shop, or you can purchase one of these.
http://motiveproducts.com/
The bleed sequence doesnt fully remove all the old fluid.
Old Aug 17, 2002 | 10:20 AM
hondafrk's Avatar
Default Re: Flushing entire brake system.... (Migs)
get like one of those turkey baster thingys that you can suck out the old fluid in the Master cyl and then fill it up with clean fluid. Pump your brakes for like 2 or 3 minutes and then drain and refill your master cyl again, then start at the right rear wheel and bleed the brakes out until you have clear fluid coming out, make sure you keep close eye on the fluid level in the reservoir, then go to the left rear and repeat until fluid is clean, then right front, then left front, then suck all the brake fluid out of the reservoir again and wipe it out with a clean lint free rag and fill it again, then your set.
Old Aug 17, 2002 | 10:40 AM
dom93hatch's Avatar
Default Re: Flushing entire brake system.... (hondafrk)
Might wanna check this out too
http://www.mityvac.com/kits.html#brakebleedingkit
Old Aug 17, 2002 | 02:34 PM
kwil666's Avatar
I thought for brake bleeding you start at passenger rear then do driver rear then move to the front and do the passenger and driver side. You start from the farthest valve and work your way to the closest.
Keith
Old Aug 18, 2002 | 05:17 AM
Default Re: Flushing entire brake system.... (kwil666)
no according to the helms manual Passenger rear, driver front, driver rear, passenger front...in that order...I know how to do that........I just couldn't get it all flushed...
THanks for the turkey baster idea...I'll try that this week...thanks guys
[Modified by SlowCivicHmm, 10:51 PM 8/18/2002]
Old Aug 18, 2002 | 01:52 PM
What's that lil gun looking bleeder that you attach to the bleeder nozzle so that no one has to pump for you?? any one know what the hell I'm talking about???
TravisCadello
Oct 13, 2008 08:42 AM
216.226.142.95:27016
Sep 23, 2004 10:16 AM
W.O.T.
Apr 1, 2003 10:48 AM
Jordan_4WS
Jan 20, 2003 02:10 PM
Kamin
17
Jun 25, 2002 12:38 PM
