Audi I5 Sheetmetal Intake Manifold
Old May 5, 2009 | 03:44 AM
Brad Campbell's Avatar
Default Audi I5 Sheetmetal Intake Manifold
Here is a little piece I have been working on for my UrS4 project. These parts are all CNC laser cut. The bent plenum parts are CNC brake bent. This is designed to be completed with some RMR runner tubes and a stock head flange. If I feel ambitious enough I will do a billet head flange. Plenum volume is around 6 liters and the throttle body will be a 3" 4.6 mustang style unless I do that from billet/scratch as well. Bores on the top hat are for additional/shower injector bosses that will be sunk down towards the ports. Im also going to machine radius transitions into the plenum base.
Old May 5, 2009 | 03:48 AM
m R g S r's Avatar
Default Re: Audi I5 Sheetmetal Intake Manifold
Niceee! I really want to try an intake manifold one of these days....gotta practice my aluminum!
Old May 5, 2009 | 09:11 PM
Sobe_Death's Avatar
I'm interested to see how the plenum-mounted injectors work out! I have always wanted to try it out on a street car but never had the chance.
Old May 6, 2009 | 03:08 AM
Well the bosses are just for secondary injectors. The primaries are buried in the head flange. Hopefully there will be no ill affects from doing it this way.
Old May 6, 2009 | 04:14 AM
914Racer's Avatar
You should look at raising the bell mouth up off the floor. It will make more power and create less turbulence around the throttle bores.
The plenum mounted injectors should work fine. Porsche used them years ago on some of their race cars. The big issue will be getting the cross over point tuned correctly, so that it smooth and doesn't lean out the motor too much.
Old May 6, 2009 | 04:18 AM
Yes sir. I was shooting to have this look similar to the Audi intakes on the 80's rally beasts. I was planning on either switching to stacks or milling the transition and cutting the floor lower just as you suggested. Thanks for the information.
Old May 6, 2009 | 09:37 AM
914Racer's Avatar
Just buy the bell mouths and bore the holes in the floor of the plenum, insert the bell mounths and weld them in place. Much easier.
Old May 6, 2009 | 09:43 AM
With RMR oval stacks at $40 a pop, I'll stick with some one-on-one time with the CNC.
Old May 6, 2009 | 12:18 PM
skylinepowered240sx's Avatar
Wow man, Very nice work. I can't wait to see the finished product!
Jay-O
Old May 6, 2009 | 05:34 PM
rota92
Guest
Posts: n/a
Looks sick!
FWIW, Kinsler has a new plenum mounted intake and I'd trust them to know whats up. You'll be fine
Old May 6, 2009 | 06:39 PM
gtconcepts's Avatar
Why it reminds me of the Dahlback unit.. u are using 10g aluminum right , I have always wonder if it will hold up?
looks good
Gil
Old May 6, 2009 | 06:58 PM
apekd's Avatar
thats SICK as hell!
Old May 7, 2009 | 08:33 AM
looks good
Gil
Everything is .125" save for the inlet tube which is 16g/.065" and the plenum floor which will be machined .5". I had designed some little bulkheads for strength on the inside, but I probably won't install them unless a backfire blows the thing to pieces.
Old May 7, 2009 | 08:21 PM
gtconcepts's Avatar
Did u used Solidworks to design it? Did u test it? flow and strength ?
Interested on the outcome tho!
Gil
Old May 7, 2009 | 09:04 PM
Karl Buchka's Avatar
Looks like a cool design. Any practical reason for the additional injector row?
Old May 8, 2009 | 02:54 AM
I did use SolidWorks for the model. No design to speak of except for the plenum volume. This will surely be an iterative process i.e. if airflow is off make a new one/if it blows to pieces, make it thicker. I think it'll be OK for a first stab. As for the additional injectors I just wanted to split up the load (and I love the way it looks). The turbo is a GT42 102mm so there will be plenty of need for fuel.
Old May 8, 2009 | 01:26 PM
Blown90hatcH's Avatar
Awesome work man. I love it when people build stuff on their own and test it. Not enough of these people out there. I would definately flow test this and would love to see a CFD done too, but props for you to getting it done.
Old May 8, 2009 | 05:42 PM
TunerN00b's Avatar
Love the angled inlet to the plenum.
5 cylinders are strange beasts indeed. Gawd I want an UrQuattro...
DANINEJDM
Jun 19, 2007 10:45 PM
Crono139
10
Jun 1, 2006 09:49 AM
turboman
Apr 7, 2004 06:39 PM
S-Type1
Jan 3, 2003 09:38 PM
Black R
Nov 20, 2001 06:26 PM
