Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
02 odyssey clock
Old May 5, 2009 | 12:47 AM
fergs96integra's Avatar
Default 02 odyssey clock
Well the clock on the odyssey works but the back light does not. Every other light on the dash works except for this one. It makes me think that its the clock light its self that is bad. Am i on the right path? thanks.
Old May 5, 2009 | 10:20 PM
marmaladedad's Avatar
Default Re: 02 odyssey clock
http://www.odyclub.com/forums/showth...threadid=17441
This will help if you plan on changing that bulb.
Old May 6, 2009 | 07:01 PM
90sedan's Avatar
8/10 times its not the bulb its the contact points on the clock itself. It's very likely that you will need to replace the clock.
Either way its an easy task, you just need to remove the panel and unscrew the clock.
Old May 8, 2009 | 04:14 AM
NDNV's Avatar
Before removing the panel to replace the bulb, try gentle smacking the dash around the clock which has been known to revive the light. At your vehicle age, it may certainly be the bulb though.
Old Jun 5, 2013 | 03:32 AM
diabolical1's Avatar
going to go about replacing the bulb on my '04 within the next few days. in the event that it's not the bulb, has anyone replaced the clock and would be willing to give me a heads up on the cost?
moss500
May 8, 2014 06:09 PM
b20quang
Honda Civic (2006 - 2015)
Mar 20, 2011 11:50 PM
lmrbtj
Feb 12, 2009 08:15 PM
ajvb65
May 22, 2008 04:49 AM
Phat Corolla
Nov 10, 2001 04:42 PM
