missfire???!!! Need help
Ok so my 98 Integra ls at idle shakes like crazy,and the check engine light calls miss fire, so I noticed cyl #1 does nothing when I pull the spark plug wire out our when I pull the injector off, so then I change the plugs and injector , still the same thing, but when I drive the car it feels fine... Any idea wat it could be??? Thanks
so which cylinder did the Check engine light say? was it multiple or only the single#1 cyclinder? if it was multiple i would suggest check the distributor or cap and rotor.
if you have never replaced your distributor cap and rotor then i would think that it is time. also it could be your spark plugs or wires.
Nick Cronk
Apr 20, 2013 06:14 PM
