Car is effed - need help!!
Hey guys...I have a 96 GSR with 212k and I noticed a small leak from the head gasket, so it was time to do some maintenance. I changed the head gasket, timing belt, cam seals, etc. I got it all back together Saturday...the car started up like normal during a cold start, but then started a low idle and shut off. The video shows what happened...give me your insight. I have no idea where to begin.
http://www.youtube.com/watch?v=1rnQrvAq0O8
I hate giving people freebees....Please use your search key next time!
https://honda-tech.com/zerothread?id=978933
Thanks again for the info. So I went out to check the code via the service connector and the cel just kept going off after I turned to the ignition switch. After a couple of times moving my paper clip around, I said well maybe I just start the car. This time the car ran and warmed all the way up to operating temp and no cel?? What the hell is going on??
Was your battery/ecu or ecu fuse disconnected at any time? These are the only things that can rest a code...Unless you of course have a scanner...But cel light keeps flashing the same codes over, and over untill they are either rest, or fixed...Even after they are fixed they cycle 3 time, then they go away completely. So what codes did you end up with?
Kinda...it turns out I had the MAP and TP sensors switched. So I switched them up and now I have a new symptom. My car is idling at almost 3k! I just drove it around the block and the car is definitely not pulling like it is supposed to. Could this be a timing issue? I checked it over and over again due to reading everyone's horror stories. Any ideas??
mstauffer67
May 14, 2018 02:40 PM
earlforeal
Honda Civic (2001 - 2005)
Jun 27, 2016 02:20 PM
new_climber
Jan 21, 2009 06:14 PM
$ISELLTOU4LESS$
Mar 26, 2006 06:36 AM
