Shift Linkage Fell off B18C tranny need some advice ( with pics) Thanks!
I have a B18c1 in a 98 honda civic sedan. I was parked in the drive way and noticed the shift linkage fell off during the night, which seemed weird. There are not any bolts or anything on the ground here are some pictures: What parts/ tools do I need to fix this problem.
Thanks
http://www.flickr.com/photos/ismaili
Thanks
There is a bolt that goes there just go to a junk yard an take it from one of those an you should be good to go aslong is a b series tho so you dont run in to many problems
From: Howcome we park on driveways, and drive on parkways?
wtf? how did that come off? im assuming the bolt and washers were never there? thats weird? you simply put the linkage back onto the bolt sticking out of tranny, there is a large washer that goes on the back as well as one on the front to keep it centered. Then its a 14mm or 17mm bolt i believe. I think it gets torqued to 40 ft/lbs as well. Once all is back on you should be good to go.
gl
gl
eghatchproject
12
Nov 22, 2003 08:28 AM
JohnnyEF
May 1, 2002 05:45 PM
