Did i blow my ringlands...again!?
Old May 4, 2009 | 01:06 PM
PhantomX's Avatar
Default Did i blow my ringlands...again!?
My cars been out of comm. for awhile...Since then I changed the battery, oil, fluids, and ignition coil out of my dizzy... so I start it up and its Miss firing and theirs a lot of vibration... i check the spark plugs and theres oil on all of them...... also theirs smoke coming from Cylinder 2 from the left (when i took out the spark plug)....
Is my motor Done???
Old May 4, 2009 | 01:41 PM
ABK's Avatar
ABK
Default Re: Did i blow my ringlands...again!?
do a compression test, better yet a leakdown. you could also open the oil cap and start the engine up. See you have alot of smoke coming out of it then you either blew a ring land or melted a pistone. If you keep on blowing engines up suggest either stop driving like a 16 year old or get a new tuner.
Old May 4, 2009 | 03:27 PM
Scheizty's Avatar
The only other thing that could get oil into your cylinder is if it came from the head or the intake. Check your charge piping and see if your turbo seals are gone. Run a leakdown and then your guessing ends.
AudioFunk
Apr 16, 2014 09:24 PM
rdssk8rcs1
May 2, 2011 03:08 AM
scUba-stEve
Dec 30, 2004 04:23 AM
VtecDA9
Apr 5, 2004 11:17 AM
jaymes2030
Jan 19, 2004 07:14 PM
