PA: Honda B, D, Trans, Block, sideskirts, mounts, linkage, injectors, hood, Greddy
Assorted B series timing covers, $20 shipped anywhere in the US.
B18B upper rear x 2
B16/GSR upper rear x1
B18B upper front x 2
OBD-1 B series lower x 3 (will work with OBD1 style B series oil pumps)
CRX DX 1.5 SOHC A/C compressor $15
93 Civic Si. windshied washer reservoir $15
93 Civic Si pass side SOHC manual trans mount bracket $10
93 Civic Si Charcoal canister $5
JDM CRX SIR (B16A) Shift linkage, not sure what you can do with it in a US spec car $20
CRX DX SOHC shift linkage $20
JDM CRX SIR (B16A) driver/pass mounts + trashed torque mount. Not sure what you can do with these either in US spec car. $10
JDM EG6 RHD clutch master cylinder reservoir. RHD conversion people need this. $5
JDM CRX SIR (B16A) A/C compressor, belt, mounting bracket and all mounting bolts $35.00
CRX DX SOHC D15 driver, passenger (not pictured) and rear engine mounts. All still have good rubber. SOLD
JDM CRX SIR B16A electronic speed sensor. Use this in your B16A CRX if you have a SIR cluster. $20
CRX DX starter $15
CRX DX alternator $15
CRX DX longblock w/clutch burns oil but runs. $50
B18B LS water pump $25 shipped anywhere in the US:
D16Z6 95 Civic Si water pump $25 shipped anywhere in US:
JDM DC2 Integra SIR-G rear lower control arms $30 shipped anywhere in US:
99-00 Civic coupe/hatch hood Sold
95 Civic hatchback pass side airbag $20
95 Civic EX auto starter $15
95 Civic hatchback steering wheel, airbag and all mounting hardware $30
95 Civic D16 axles $30
CRX DX D15 axles $30
B18B upper rear x 2
CRX DX starter $15
where you located in pa. i need timing belt covers top and bottem. crx shift linkage if it will fit the hatch.
highmilehatch
Northeast (Sales)
May 29, 2009 10:02 AM
