swapping clusters...keeping milege...
Old May 4, 2009 | 10:57 AM
hotcivicsi's Avatar
Default swapping clusters...keeping milege...
Purchased a cluster with a tach to swap with my 98 DX cluster with no tach. Is there a write on how to change speedometers for the 96-00 Civic because I found one for the 92-95 but dont know if its the same.
Thanks
Old May 4, 2009 | 11:05 AM
BlueIntegraBoy's Avatar
Default Re: swapping clusters...keeping milege...
They're not the same. You will need a 96-00 Civic cluster.
Old May 4, 2009 | 11:09 AM
hotcivicsi's Avatar
O I know that I bought the same year cluster....what I meant was I found the how to for the older cluster....but I think I got it basically the same thing just a couple more clips and screws
Old May 4, 2009 | 11:26 AM
geneeunit's Avatar
depending on the cluster you bought, you can swap odometers. if you bought an ex cluster, just open them both up and swap the whole speedo unit, it works the same. if you bought an si or something where the gauge face is different from your current faces, you can follow the diy for the 92-95 because its very similar. i can take pictures for you if you want also, but its really quiet simple. just dont touch the faces with your fingers, and if you are changing to something with a different face, be careful removing the needles.
Old May 4, 2009 | 12:23 PM
To swap the odo/speedo, remove the cluster bezel. Unscrew the 4 screws behind the speedo gauge and swap.
Old May 4, 2009 | 02:53 PM
hotcivicsi's Avatar
To anyone wondering the same thing, heres a how to for the older cluster which is pretty much the same thing for the 96-00 clusters. takes maybe 20 min to do the complete swap and install.
http://www.superhonda.com/forum/f94/...-420kb-274853/
drgooch
Jul 5, 2013 09:08 PM
gramkrackers
Jun 26, 2012 04:37 PM
mugenpowered
12
Apr 29, 2006 02:01 PM
92LXCivicAccord
Jul 28, 2005 09:21 PM
GsR HtCh
Aug 14, 2002 01:39 PM
