Removal of drive pulleys?
Im trying to replace the crank shaft seal due to an oil leak and im stuck not being able to get the drive shaft pulleys off. I am using a strap wrench to try to hold the pulleys from rotating but I have had no luck. Every time I try to crank on the bolt the pulleys still are able to slip in the strap.
Any one have a better method to getting these off. I would but the car into gear to stop them from moving but the car is has an auto trans
isnt there an access panel on the tranny where it meets the engine and using a hole in the flywheel/torque converetor thingie you can hold it in place to keep it from rotating. dont bend anything though
you need this, or the 50 mm version, don't remember for sure which one i got, but this is what you need.
http://www.amazon.com/Alltrade-64881.../dp/B0002Q8TR8
You can build something like that with some pipe fittings. I think it's like a 1 1/2 inch reducer, a T fitting and a section of pipe. Anyone want to explain how to make that one or find OP a link?
Easiest way, take it to a shop, have them take off the bolt. Then have them tighten it a little bit, so you can drive home and take it off.
I tried everything man, took a nice 2 big chunks out of mine before I could get it off.
I do have the 50mm hex tool if you want to borrow it, just pay for shipping both ways. Also need a $30 deposit that will be returned when I get the tool back.
I pm'd you. It'll be around the same cost if you just buy one from Amazon from what RonJ posted, $24.99 is a little more than what shipping both ways will cost. Plus, there's free shipping on that if you add a small item like $1 to bump it over $25.
ok im going to try paypal now. i may just buy the tool as im sure ill be needing it again
imptricer
Nov 13, 2010 06:43 AM
sean burke
May 6, 2009 08:15 AM
Drew17th
24
Sep 7, 2006 08:36 PM
sol_tuner
21
Mar 17, 2005 01:17 PM
GroundZer0
21
Aug 30, 2002 03:56 PM
