Best way to re-wire the front speakers
Old May 4, 2009 | 09:52 AM
bopbop93030's Avatar
Default Best way to re-wire the front speakers
Are there any technique's to do this.
I went ahead and take a look at it this morning and it's going to be a pain.
The only thing I can think of is run the wire by the side of that rubber/ plastic thing by the door where the wire's at from the window and then just wrap it with black electrical tape.
Any other suggestions?
Old May 4, 2009 | 10:21 AM
infinitypro12's Avatar
Default Re: Best way to re-wire the front speakers
I'm not 100% but it should be the same as the post I started this weekend. There should be an empty hole in the power harness that you can drill out but you want to unplug it and the neg. batt. cable before you do so to be sure. or you can run a new hold from car to door with a tap and drill. It is going to be difficult but I like to think it is going to be worth it. As far as other suggestions you can keep it in the car by buying kick panel enclosures which look cool but in my opinion they are dummy proof and I wouldn't trust anyone to get in my car an not step on them. GL.
Old May 4, 2009 | 10:51 AM
KRock459's Avatar
Its easiest to remove the front fender to get to the inner door jamb where the rubber boot goes into the vehicle. As mentioned above, you will need to seperate the plasic plug in the door and drill holes, pretty easy stuff.
Kirk R
Old May 4, 2009 | 01:17 PM
Could you link your post here.
Thanks!
Old May 4, 2009 | 01:50 PM
I'll 1up you, I'll PM you what I pm'd 98civdx...and if you sqsi around remember to thank him if this solves your question.
You've got mail!
EvenStar
Oct 25, 2008 07:48 AM
bopbop93030
May 14, 2008 12:45 PM
pez1
Apr 11, 2006 09:22 AM
BrainzIRL
Audio / Security / Video
Feb 23, 2006 01:20 PM
Dr Pooface
Sep 12, 2001 10:56 PM
