noise in suspension
theres a noise comin from my front suspension can figure it out its a knocking sound its not a cv joint i know that happens when im stopping right before a complete stop it does it....i dunno its weird maybe tie rods?
Radius rods have a bushing and nut in the front, when those get loose or "untightened" you'll hear a "pop" and other noises from the front. I would go check them out and tighten them. It worked for me.
i got the same noise! mine does it when i turn the car and turn the wheel back. or when im stopping sometimes.
remember, a boot doesn't necessarily have to be torn in order for a CV to be bad.. the way you tell if you're CV boot is bad is if you go to a parking lot and drive in a CONSTANT RADIUS and it clicks... if you do not drive in a constant radius, it can be mistaken for loose radius rods...
i got da same problem on my EF. yah, my one had really bad rubbers on da end of da radius rod. my mechanic replaced it with some spare rubber bushing he had laying around da shop. problem solved yesterday so its all good. i think with our cars, i think its time to buy new bushings.....gettin kinda old.
Mine does that too, what exactly needs to be tightened? Mine usually does it when I start from a complete stop or if I brake hard I'll hear it. It seems to do it when the weight is being shifted in either front or rear directions. I was thinking maybe the stab. bar needs adjusting.
i put the prothanes in mine last summer and it`s wonderful . you turn the steering wheel and you go there. point and shoot. if you do go urethane get a softer spring or adjustable shock . with the whole kit in the car it gets a little harsh so you should have a little adjustment in your suspension. i have my car dropped 1 inch and everyone trips on it . their like - do you even have it lowered at all?- you don`t need to dump it to handle good.i kill em in the twisties .
GagnarTheUnruly
Jul 26, 2011 02:51 PM
littleblue
13
Jul 27, 2006 09:15 PM
lowRIDAH
10
Nov 18, 2004 06:18 AM
