help!? head gasket or not!?
Old May 3, 2009 | 11:05 PM
soulo's Avatar
Default help!? head gasket or not!?
Okay..after my cousin change my valve stem seals, my car stop the blue smoke...and 1 week later (which is today) it started to white smoke alot...its it the head gasket? and is there a HOW TO -head gasket on b18c1. i search the forum but end up with no luck..thanks guys!
Old May 4, 2009 | 09:51 AM
mouab18c1's Avatar
Default Re: help!? head gasket or not!?
check compression. check to see if there is white milky stuff under your oil cap/valve cover. also check if there is oil in your IM by looking through your TB
Old May 4, 2009 | 10:37 AM
soulo's Avatar
okay...last week before the vaule stem seals, the compressson were 210,195-197,210,210 (around 210) just did the compresson test it came out all 195-198 on all 4 cylinder. cylinder 1 and 2 spark plug is freakin wet. could it be crack sleeve? piston melted? head gasket?
Old May 4, 2009 | 04:13 PM
mouab18c1's Avatar
wet? does it smell like gas?
Old May 4, 2009 | 07:30 PM
soulo's Avatar
not to sure.....
Old May 5, 2009 | 09:36 AM
mouab18c1's Avatar
take your spark plugs out and let the fuel evaporate...
Old May 5, 2009 | 06:11 PM
soulo's Avatar
is there any how to take off the head then?!
Old May 5, 2009 | 07:20 PM
Blown90hatcH's Avatar
www.helminc.com
Those compression numbers seem good. Did you do a leak down test?
Old May 5, 2009 | 08:50 PM
soulo's Avatar
no..not yet....i dont have an air compressor.
this is for a b18c with srp piston/eagle rod compression 9:1 81.5mm with blockguard.
Old May 6, 2009 | 06:55 AM
mouab18c1's Avatar
you have low comp pistosn so with those numbers they are still good...if your paranoid about it then just change it...kind of hard to say when we're not there inspecting it
Old May 8, 2009 | 10:33 PM
soulo's Avatar
according to what my cousin was saying...he said that its my turbo that went bad. its leaking into the down pipe to cause it to smoke....but one thing that i notices, why is my spark plug wet? (he said that it because of my O ring on my valve cover) how can that wet the spark plug? and the piston!? it cannot wet the piston unless i take off the the spark plug correct?
Old May 9, 2009 | 07:16 AM
KWayRacing's Avatar
Correct. Those compression numbers are good. You could eliminate the possibilty of the turbo by unbolting it and running open manifold. I dont mean drive it this way or even remove the turbo from the vehicle. Just get it away from the exhaust stream. If the some pours you at least know it is not the turbo. NOTE, your car will be VERY loud like this. How Long has this setup been put together? Is there oil in the Charge piping? Good Brand turbo? ????
Old May 9, 2009 | 09:29 AM
soulo's Avatar
yes its a good brand turbo. its a turbonetic. i drove around with this turbo for one week. so your saying that remove the turbo from the manifold? and let it run to see if it still drip?
shm91
Sep 1, 2013 03:56 AM
Nicolai
Jun 16, 2013 03:38 PM
ToTriggerHappy
Jan 3, 2010 10:11 AM
boostedjdmdc2
Jan 13, 2009 10:49 AM
skUnK2jdm
Jan 30, 2007 05:36 AM
