distributor swaps on H22A?
i was just wondering if any of the F series distributors with external coils can swap onto the h22a head or if im just better off buying a external coil distributor for a prelude?
Don't know for sure, but I'm going to guess that the f has a different bolt pattern.
But, you can make a few small wiring changes and run the internal coil dist just fine, not sure if that helps.
what wireing do you have to do to keep the internal coil ( i did a h22 swap into my 92 si and left the h22 distr. on , am i supposed to wire anything or will it work w out wireing?)
fuckaBitch16
Mar 7, 2006 12:45 PM
