I finally put it on the dyno and it could have been better.
Old Aug 16, 2002 | 08:44 PM
TypeR-R6's Avatar
Default I finally put it on the dyno and it could have been better.
Dynoed a baseline of 150Hp and 110torque with AEM, DC 4-1, 5 Zigen Exhaust, Cam gears, and a FPR. After tuning we got it up to 164 and 118 and it was done on a dynojet. I will post the dyno sheets later but I would think that it would be closer to the 180 range. Any ideas? The power jumped up from moving the intake cam to +4 the exhaust cam really didn't affect the car either way. I had the FPR set to 42psi and played with that but initially it was running to rich and after all the tuning I still seem to have A/F problems.
Old Aug 16, 2002 | 08:56 PM
Bob#455's Avatar
Default Re: I finally put it on the dyno and it could have been better. (TypeR-R6)
164/118 sound like STOCK numbers. I don't think the DynoJet's vary by that much...I hope you didn't get a weak motor.
Old Aug 16, 2002 | 08:58 PM
itr1244's Avatar
Default Re: I finally put it on the dyno and it could have been better. (Bob#455)
is it a R or what?
that's pretty low
even some stocks do like 175ish
Old Aug 16, 2002 | 09:48 PM
CPR's Avatar
CPR
I noticed you're from VA. I think the weather might have a little something to do with your less than par numbers. I say wait till it gets a little cooler to diminish the effects of heatsoak. Where in VA are you located if you don't mind sharing.
Old Aug 16, 2002 | 11:06 PM
HybridKOOP's Avatar
Default Re: I finally put it on the dyno and it could have been better. (itr1244)
is it a R or what?
that's pretty low
Wrong
Old Aug 16, 2002 | 11:19 PM
GokuSSJ4's Avatar
Default Re: I finally put it on the dyno and it could have been better. (HybridKOOP)
stock more like 165whp
but 118tq thats low
Old Aug 17, 2002 | 12:01 PM
Racebrewer's Avatar
Was that corrected for temperature, barometric air pressure and /or humidity?
If not, do you recall what the weather was like that day? It makes a huge difference.
John
Old Aug 17, 2002 | 12:08 PM
Art Vandeleigh's Avatar
Default Re: I finally put it on the dyno and it could have been better. (Racebrewer)
here are my numbers
this was done in boston in the month of july. the temp was well over 80 F and the humidity was....welll you know how boston is, if you dont its like ASIA in the summertime. anyway, those numbers are really low with all those mods on there. how old is your ride? how many miles on the motor? what year?
jope things work out for you
Old Aug 17, 2002 | 06:32 PM
TypeR-R6's Avatar
Default Re: I finally put it on the dyno and it could have been better. (up-youRs)
The temperature was about 95 with humidity that felt like 110. It was done in Va. Beach at Abacus Racing. The run was not corrected for temperature. We set the intake cam at +6 and the torque and Hp increased around 20Hp between 3k and 6k but the when you looked at the a/f graph there was a break in the line at about 6.5k and the tuner said that we should set it back to +4 because of that. The car has 36k miles on it.
Old Aug 17, 2002 | 10:18 PM
PiYoImuT's Avatar
seemed low for a DynoJet number..
on a Cool day, most of Pittsburgh Stock ITRs put down 153-157 WHP..
on a Hot day, 145-150 WHP..
That's on a Mustang Dyno..
hondachris1994
Mar 13, 2009 03:20 AM
VtecKiDD
22
Nov 3, 2004 10:12 AM
ZC'n'it
Oct 14, 2002 01:40 PM
-Whitey-
Oct 10, 2002 04:02 PM
SiBirdie
Aug 1, 2001 09:38 AM
