How to remove the rear windows for the eg?
Old May 3, 2009 | 12:21 PM
denso's Avatar
Default How to remove the rear windows for the eg?
Hello everyone, I am trying to remove my rear quarter windows on the 92 civic hatch but I can not figure it out, and i don't really want to F*** it up. If anyone has information please let me know.
- Thanks in advance
Old May 3, 2009 | 12:23 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: How to remove the rear windows for the eg?
I've personally done this myself years ago when i had a complete color change done to my 1992 CX HB.
You'll need a special tool that is basically like a piece of piano wire with a handle on one end, and a hook on the other.
I started mine by pulling the rubber trims out of each side, then cutting the urethane holding the glass in with the special tool for cutting windows out.
You do understand that you'll need new trims and an automotive glass company will need to reinstall them with new urethane, right? It wasn't necessarily cheap when I had it done.
Old May 4, 2009 | 03:04 PM
cleansi's Avatar
its pretty easy like the guy said above a piece of piano wire or a thin wire. have your buddy inside and you out side then just pull the wire back and forth till the rubber seal is cut all way round DO NOT PULL ON THE GLASS TO TRY TO RIP IT OFF HALF WAY THOUGH TI WILL CRACK EASILY. wait till its all cut you can use old mouldings but the actual rubber seal u can get at autozone what ever parts store its just a liquid winshield cocking look 4 it then use a cocking gun spread a small stream around where the old seal was then paste and hold you will have to support the window until its cure then pop the oem black trim back on if your hatch has it
Old May 4, 2009 | 03:08 PM
jeffsciv23's Avatar
big rock
SCMFOX
Dec 21, 2017 09:16 PM
Inferno^
Sep 22, 2009 07:34 AM
b20a1
Mar 3, 2007 04:27 PM
savagenomore
Jan 27, 2007 10:11 PM
y49crxsi
Feb 21, 2004 05:53 AM
