GSR Block knocking. whats making it knock?
Old May 3, 2009 | 11:46 AM
d16turbocoupe's Avatar
Default GSR Block knocking. whats making it knock?
okay so i have a gsr b18c1 motor and its been knocking ever since i gunned it the last time. the previous over just replace all the bearings he stated me, it drives and all and when i start to drive it the knocking stop for alittle bit then its starts knocking again... and when i slow down the motor dies. i thought it was my head knocking so i change the head and it still do the same thing.. what could it be and what should i do?
Old May 3, 2009 | 11:49 AM
jax97hx's Avatar
Default Re: GSR Block knocking. whats making it knock?
your motor is most likely super fuked up by now
knocking is normally the result of a spun rod bearing and after it happens and you keep driving on it it takes alot more than just slapping some new ones in there
Old May 3, 2009 | 11:58 AM
i havent drove it since its been knocking. right after i heard it knocking i had it towed back home. im just stating what happens when i first heard it knocking and i slowed down and the motor just dies. cars just been sitting in my garage. then i change the head and it still doing the same knock knock sound. so its still can be save and put on new bearings on right..?
Old May 3, 2009 | 12:11 PM
jax97hx's Avatar
honestly you could try and slap in bearings without pulling the motor
but...
the best thing to do would be to take out the motor remove the crank and spend 20 bucks at a machine shop getting it polished then mic the journals and put in the appropriate honda color bearings
check out this vid it talks about finding the right bearings
http://www.youtube.com/watch?v=MtTXA...e=channel_page
preludeboybmw
Sep 29, 2010 04:21 PM
eg4life1202
Sep 4, 2006 06:03 PM
JDM_EK_JOE
May 13, 2006 06:03 PM
mnskateboarder
Apr 18, 2005 04:55 PM
CrX-To-Tha-Max-v2.0
Mar 2, 2005 10:49 PM
