Name this Relay - 89 Honda CRX
Old May 3, 2009 | 11:38 AM
CRXB18C1_ALL MOTOR's Avatar
Default Name this Relay - 89 Honda CRX
What is the difference between this relay:
and this relay:
Car won't start and suddenly died on the freeway going about 65mph cruising. Tried to restart and no luck. Got it towed back home and did a compression test. 245/245/240/240. Brand new distributor installed last week. When key is turned to #2 position dash lights come on, check engine light comes on then turns off within 2-3 seconds. When trying to crank the car, it does not start. When key is at #2 position, I don't hear the fuel pump priming at all, however I hear a click and then the check light goes away.
What could it be? Which relay would you change first? Thanks.
Old May 3, 2009 | 11:41 AM
dtapia's Avatar
Default Re: Name this Relay - 89 Honda CRX
the top relay is a 4 pin relay used in fan circuits and head light's
the second relay is a EFI main fuel relay.
Old May 3, 2009 | 11:46 AM
I removed the top relay (4-pin) from underneath the drivers side fuse panel - next to the hood release lever. Where is the main relay located on a CRX? I can't seem to find it. Thanks.
Old May 3, 2009 | 12:31 PM
fcm's Avatar
fcm
Old Fart
http://www.tegger.com/hondafaq/mainrelay.html 94
Old May 3, 2009 | 01:52 PM
dtapia's Avatar
cool site FCM
yea the relay is fun on that year.
Brand
21
Sep 8, 2022 09:39 AM
EK B18c
22
Apr 21, 2012 03:08 PM
wisebear1
Dec 6, 2010 09:24 PM
ninjarich2
May 11, 2007 12:51 AM
NazVil86
Oct 10, 2006 06:44 PM
