if i remove power stering belt is that good enouf to disble power stering?
i dont want power stering but i dont want to take everything out so when i sell the car i can just put it back onn can i take the belt out and is going to be safe ??/
Yeah you should be fine... drain a bit of the fluid outa the resivoir also to avoid any messes... save the belt just in case you change your mind...
