Are arp flywheel bolts a must?
Old May 2, 2009 | 11:38 PM
ss396rat's Avatar
Default Are arp flywheel bolts a must?
I got a b20v with gsr tranny, Do I need to use the arp fly bolts?
Old May 3, 2009 | 03:47 AM
non-VTEC's Avatar
Default Re: Are arp flywheel bolts a must?
something wrong with the oem flyhweel bolts?
Old May 3, 2009 | 07:21 AM
ss396rat's Avatar
I don't have any bolts for the flywheel, I'm just wondering if I should go get stocks or arp's.
Old May 3, 2009 | 07:27 AM
96Spec Ek's Avatar
I've read on ht of some people having issues with certain flywheels using arp bolts. They apparently are too long for some applications. I bought new oem ones from majestic honda online. They were about 3 dollars a piece and you need 8 of them.
Old May 3, 2009 | 07:39 AM
ss396rat's Avatar
I just went on majestic's website, and I can't find the bolts anywhere. Could you send me a link. their catalog is huge.
Old May 3, 2009 | 08:03 AM
Fink29's Avatar
Here you go. http://www.hondaautomotiveparts.com/...RQUE+CONVERTER
Old May 3, 2009 | 08:46 AM
mar778c's Avatar
Community Builder
Community Influencer
96Ekspec is 100% correct about the flywheel bolts. I recommend that you check with the clutch manufacturer to be sure.
Old May 3, 2009 | 08:58 AM
sh!tsWEAK!'s Avatar
They won't hurt, but they aren't necessary. If you don't have bolts and need to get some anyways then might as well get the ARP's.
Old May 3, 2009 | 09:43 AM
ss396rat's Avatar
Originally Posted by Fink29
Got the stock fly bolts and a clutch case cover. Thanks for the link.
Old May 4, 2009 | 04:40 AM
FST GSR 1's Avatar
Just to chime in late here... ARP flywheel bolts are nice but do require some turning on certain flywheels. I have a Fidanza and had to remove 4mm from mine.
Old May 5, 2009 | 08:36 PM
bigodub93's Avatar
i say the stock one will work just fine.
--------- late ------------
Axatax
Transmission & Drivetrain
Jul 17, 2012 12:27 PM
rebel831
Jun 14, 2011 08:05 PM
sawedoffcoupe
Jul 28, 2008 04:01 PM
Caveman74
Jun 2, 2006 02:46 PM
igo4bmx
Nov 25, 2004 09:43 PM
