over heating, sputering, white smoke=bad thermostat?
Old May 2, 2009 | 10:09 PM
futurefastguy's Avatar
Default over heating, sputering, white smoke=bad thermostat?
so as the title states, can a bad therostat be the problem? or is it what i think it is....
Old May 2, 2009 | 10:12 PM
XKINGX's Avatar
Default Re: over heating, sputering, white smoke=bad thermostat?
its prolly what u think it is. it could have started as a bad thermostat. the sputtering is prolly from running hot and the fuel evaporating before it can ignite.
Old May 2, 2009 | 10:13 PM
XKINGX's Avatar
the white smoke is what engine coolant looks like after it goes threw the engine
Old May 2, 2009 | 10:17 PM
Sic_DA_Nine's Avatar
those are all symptoms of a blown head gasket.
Old May 2, 2009 | 10:18 PM
jdp1978's Avatar
I had that happen to me ended up being a blown head .Does your oil cap look like it has coffee w/cream looking liquid in it ,if so blown head
Old May 2, 2009 | 10:24 PM
XKINGX's Avatar
It all depends where the gasket blew. if oil is getting into the coolant the radiator will have a nasty milky looking **** in it. if the coolant is getting into the oil the oil cap and dip stick will show signs of the milky ****. if its leaking inbetween the cylinders u will just get white smoke out the tail pipe
Old May 2, 2009 | 10:33 PM
TravisCadello's Avatar
you blew the head gasket.
DRoylflush
11
Apr 10, 2011 02:11 PM
gmboogy
Nov 29, 2006 01:44 AM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
sambam27
Dec 5, 2004 09:39 AM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
