fule and spark problem
Old May 2, 2009 | 11:20 AM
isaygo's Avatar
Default fule and spark problem
i have a 1995 civic and im not getting spark , and im not getting fule unles i try to push start it . wat would it be
Old May 2, 2009 | 11:36 AM
R666_EK's Avatar
Default Re: fule and spark problem
Check fuses and relay.
Old May 2, 2009 | 11:39 AM
isaygo's Avatar
yea thats wat im in the prosses of doing but i dont have the fuse box diagram. the spark is intermittent. but the fule is wat weird to me im only gettin fule in the fule rail when i kick start it
Old May 2, 2009 | 11:42 AM
1992Si's Avatar
You should be getting fuel pressure with the key in the on position.
No spark is most likely something in the dizzy. Go buy a rebuilt dizzy from the auto parts store. Trust me just buy the rebuilt dizzy. Remember everything in there is, how old?
If the fuel pump is not working with the key on, clean the ecu ground on the thermostat housing.
Old May 2, 2009 | 11:46 AM
isaygo's Avatar
ok but why am i not getting fule
Old May 2, 2009 | 11:56 AM
Former User's Avatar
Are you saying you are getting fuel when the key is in ON(II) (for push start) but not in ON(III) using the starter. If so, check the ignition switch.
Phantastic
May 28, 2010 03:15 PM
curiousgpnoy
Oct 9, 2009 03:03 PM
camp_kill_yourself
Apr 20, 2007 09:31 PM
quad
20
Mar 14, 2007 05:16 AM
vietjdmboi
Mar 8, 2005 06:33 PM
