1/4 time question
went to the drag strip in february. ran 13.13 @ 107.4 in no wind and about 70 degree weather. 60ft was 2.0
went to the track yesterday. ran 13.15 @ 104 in 13 mph cross wind and about 55 degree weather. 60ft was 2.1
with this info in mind, am i possibly good for 12's?
thanks
i had newer stiffer suspension 10k/8k and a torque damper when i ran yesterday but not in february (stock suspension).
what should i be running or expect to?
thanks
I will post up a time slip when i get out of class. here is my setup though...
i have 2000 integra type R
JRSC @ 8 psi
samco intake with bpi velocity stack
endyn kamikaze header
thermal 3" exhaust
methanol injection
PIC suspension 10k/8k
Ingalls Engine Torque damper
i was on bfg drag radials 225/50/15 at 25 psi. for some reason when i had it at 15 psi, i would bog off the line no matter what i launched at. i guess due to the cold weather?
the last time i ran in february same setup with tires but did not was on STOCK suspension and no torque damper but at 15 psi....
any advice would be great
****added 60ft info to first post****
JRSC @ 8 psi
thermal 3" exhaust
methanol injection
also in february, without my new mods, i consistenly ran 13.15, 13.13, 13.17, 13.14 all day. no problems or bogging. im assuming weather because i have never ran in that cold of weather before...
Put some slicks on it, preload the **** out of it, get that 60ft down to a 1.6-1.7 and you will see a 12 second pass after a 12 second pass after a 12 second pass...etc
