1/4 time question
Old May 2, 2009 | 08:52 AM
gosu08's Avatar
Default 1/4 time question
went to the drag strip in february. ran 13.13 @ 107.4 in no wind and about 70 degree weather. 60ft was 2.0
went to the track yesterday. ran 13.15 @ 104 in 13 mph cross wind and about 55 degree weather. 60ft was 2.1
with this info in mind, am i possibly good for 12's?
thanks
i had newer stiffer suspension 10k/8k and a torque damper when i ran yesterday but not in february (stock suspension).
what should i be running or expect to?
Old May 2, 2009 | 09:23 AM
jjspec's Avatar
Default Re: 1/4 time question
What is your setup? Street tires/drag slicks, etc. Post up the whole timeslip also.
Old May 2, 2009 | 09:35 AM
Hanmin's Avatar
I'd say your good for 12's test out different size tires.
Old May 2, 2009 | 10:32 AM
gosu08's Avatar
I will post up a time slip when i get out of class. here is my setup though...
i have 2000 integra type R
JRSC @ 8 psi
samco intake with bpi velocity stack
endyn kamikaze header
thermal 3" exhaust
methanol injection
PIC suspension 10k/8k
Ingalls Engine Torque damper
i was on bfg drag radials 225/50/15 at 25 psi. for some reason when i had it at 15 psi, i would bog off the line no matter what i launched at. i guess due to the cold weather?
the last time i ran in february same setup with tires but did not was on STOCK suspension and no torque damper but at 15 psi....
any advice would be great
****added 60ft info to first post****
Old May 2, 2009 | 10:39 AM
gosu08's Avatar
also in february, without my new mods, i consistenly ran 13.15, 13.13, 13.17, 13.14 all day. no problems or bogging. im assuming weather because i have never ran in that cold of weather before...
Old May 2, 2009 | 01:58 PM
JdMhEaD's Avatar
Put some slicks on it, preload the **** out of it, get that 60ft down to a 1.6-1.7 and you will see a 12 second pass after a 12 second pass after a 12 second pass...etc
JDeez_1212
Mar 11, 2012 07:22 PM
DD_JonnyLee
Aug 22, 2011 12:09 PM
cmasonrun
Nov 1, 2007 06:14 PM
THE GAME IS THICK
Aug 30, 2005 06:27 PM
94_civic_guy
Aug 18, 2003 04:45 PM
