B16 safe for turbo?
Old Aug 16, 2002 | 06:38 PM
charjacq's Avatar
New User
Default B16 safe for turbo?
Is the B16 strong enought to hold boost? I just realised how high the compression is....low compression is better for turbo....I might be better off with a B18 then...decision time!!!
Old Aug 16, 2002 | 08:15 PM
Giuseppe's Avatar
Default Re: B16 safe for turbo? (charjacq)
can i have this one...?(my first)
DO A SEARCH..!
Old Aug 16, 2002 | 08:22 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: B16 safe for turbo? (Giuseppe)
lol, i was much too lazy to respond with that
Old Aug 16, 2002 | 10:03 PM
charjacq's Avatar
New User
Where can I find this info? I did search around, but most say high compression is not good for turbo. Can I put in different pistons to lower the compression and then slam a turbo on it?
Thanks for any info.
Old Aug 16, 2002 | 10:24 PM
Veil_Side_'s Avatar
yes you can, and yes B16A are good for turbo, lol. Oh man, sorry, had to laugh at this post. You can even get an answer from some of the member's title/name.
Old Aug 16, 2002 | 10:47 PM
Giuseppe's Avatar
(scratching my head)
turbo ls vs. turbo b16a1?? power and 1/4's
Another B18B vs B16A [Archived
whats a better turbo motor B16A or B18A/B? [Archived]
Civic going turbo, need to know what motor is better B16A or B18A [Archived]
COmpairing a turbo b18b to a b16 USDM. [Archived]
Old Aug 17, 2002 | 06:47 AM
Ltech's Avatar
Get you a good book and you have a lot of reading to catch up. Maximum Boost is awesome. I have a b16 and here is my list
GE sleeves bore 84mm
JE pistons 9:1
Eagle Rods
Cometic head gasket 0.036mm
Head done by Port Flow
Ferrea package, over size valves .5mm
Open Combustion chamber to match 84mm bore
Gsr cams
Skunk 2 cam gears
Vict X manifold
DSS stage 3 axles
ARP head studs
Action clutch(pro)
Quaife lsd
ACL bearings
Balance bottom end
And many more i can't remember to list all
B16 can make you hp if you do it right. My goal is 450-500hp
I'm still looking around for a good turbo(a good price i mean)
Old Aug 17, 2002 | 02:05 PM
Default Re: B16 safe for turbo? (Ltech)
hey Ltech, i know it is hard and painfull to collect your receipts, but i wonder how much the motor work had cost you? that looks like a damn good set up.
which turbo are you looking for? and how many PSI?
good luck with it, that is my goal as well, have a A3 boosted with a moderate level.
stan
Old Aug 17, 2002 | 02:58 PM
Giuseppe's Avatar
Default Re: B16 safe for turbo? (ridge racer 2)
Actually higher compression is better for boost
wow..really.??
please explain....
Old Aug 17, 2002 | 03:00 PM
NikoZai's Avatar
i was just thinking about this Garret T3/T25 turbo i just saw on ebay. it's selling for $200, hour left to bid. I wont jump on it but it got me thinking wether or not a non built b16a like mine would hold 8psi no problem and make a good 40hp?
I would probably need bigger injectors, intercooler, piping for the damn thing.
any insight? anyone done it?
p.s. tell me to search it and i'll bitch slap yo ***
Old Aug 17, 2002 | 04:41 PM
Ltech's Avatar
Default Re: B16 safe for turbo? (NikoZai)
I used to collect my receipts but not anymore because looking at it make me wanna cry. But this is what i remember
89 crx hf $500
B16 motor with s1 tranny $1500
GE sleeves with JE pistons $1450
Head work by Port flow
Port and polish, ferrea valve tran over size valves and open up combustion chamber to match 84mm bore $1950(uh i get free shipping on this lol)
Cometic head gaket $113
Body work $4g(car still in the body shop)
Roll cages 6 points chromoly $650
Balanced bottom end FREE
Hasport billet aluminum amount $356( I think)
Action clutch(pro) $450
DSS axles stage 3 $750
Eagle rods $325
Vict X manifold $290
New timing belt, water pump, tenioner, oil pump, gaskets around $500
Fluidyne radiator around $350(i forgot)
skunk2 cam gears $175
GSR cams $65 off 99 gsr
Harmonic balancer $100
ACl bearings $96
ARP studs $105
Quaife lsd $760
Supra tailight $150
Is 300 head light $380 without HID bulbs
Mugen body kit $575
Autoloc shaved handles kit $250
Right fender $145
I;m sure there are tons of other stuffs i forget so please add up my total
FUTURE PLAN
Inline pro mani, t3/04e turbo, Gtr i/c, hondata stage 2b. Planning to get this thing run 20 psi + . My car won't be back from the body shop for another 2 months. Hopefully I can get this beast ready by the end of the year.
[Modified by Ltech, 5:50 PM 8/17/2002]
Old Aug 17, 2002 | 06:20 PM
bryant's Avatar
yes i have heard about this also. But i think so many ppl here just want to run pump gas and not worry about really tunning it to the fullest so they just drop compression and call it good.
Old Aug 17, 2002 | 07:43 PM
MrTodd's Avatar
Default Re: B16 safe for turbo? (CR-X)
Yeah the high compression of a B16A combined with a turbo does not like pump gas. Of course, it depends on how much boost your putting in!
Higher compression = more power, boosted or not. If that's what you would call 'better'
As for the B16 itself, it's ready for a turbo. I mean, all B-series motors have nice beefy rods, and strong pistons.
You might be safe using pump gas if your running no more than 6 psi intercooled? I really don't know, that's just a guess....
Old Aug 17, 2002 | 08:51 PM
NikoZai's Avatar
Default Re: B16 safe for turbo? (MrTodd)
cant ya just keep buying octane booster and add it to each tank religiously? doesnt seem like that big of a hassle to me, just add's another 5$ per tank (if you buy a box)
Old Aug 17, 2002 | 09:15 PM
memphiss13's Avatar
isn't a stock b16 safe at about 7 psi. what i wonder is, does the JDM b16 with 10:4:1 hold boost just as good as the U.S. in stock form
Old Aug 17, 2002 | 09:32 PM
very cool! plenty of money spent here, looks like spent well too.
post pictures when you feel it is ready for it
stan
Old Aug 18, 2002 | 12:21 PM
ricodemus's Avatar
Default Re: B16 safe for turbo? (90crxsi)
I'll tell you one thing, my friend had a t4 on a b16 (2nd gen) and blew it up within a week on 5psi. be careful running stock b16s with boost. make sure you are tuned! I'm not making the same mistake.
Old Aug 18, 2002 | 03:24 PM
Ltech's Avatar
Default Re: B16 safe for turbo? (ricodemus)
T4 on a b16 ? I'm jealous I can't wait.........
CRXherbie91
May 25, 2008 08:23 AM
crxfreak1117
Aug 15, 2007 08:45 AM
94hatchvx
Nov 5, 2006 09:34 PM
Boostage
Apr 11, 2005 07:11 AM
MUGENTYPER
Feb 6, 2002 06:31 AM
