car wont idle
Old May 1, 2009 | 09:20 PM
turbozcsol's Avatar
New User
Default car wont idle
hey guys, i just swapped a turbo`d sohc zc vtec into my 93 del sol it is running on a chipped/tuned p72. now onto my problem when i start the car it will crank and instantly dies if i give it gas it will stay alive but the second i stop giving it gas it dies any idea what could be goin on....
if you need any more info just ask....
thanks for any help to come
Old May 1, 2009 | 11:03 PM
Jimmy's Avatar
Global Moderator
Default Re: car wont idle
What are you running for fuel management? What injectors? I see you posted chipped p72, but is it tuned since the swap? ANY CEL?
Old May 2, 2009 | 06:43 AM
turbozcsol's Avatar
New User
i am running RC 440`s and the p72 is chipped on crome and came with the swap it ran good in the car it came out of but it has not been tuned since i put it in and i will check for CEL real quick
Old May 2, 2009 | 06:51 AM
Former User's Avatar
Have you checked the mechanical timing?
Old May 2, 2009 | 07:07 AM
turbozcsol's Avatar
New User
yes sir, it is spot on
Old May 2, 2009 | 07:14 AM
Did you find a CEL?
Sure sounds like a timing issue.
Are the plugs and injectors in the correct firing order?
Have you measured the fuel pressure?
Old May 2, 2009 | 09:47 AM
turbozcsol's Avatar
New User
got it fixed had a pretty bad vaccum leak idles right at 800 now
splashy
Apr 1, 2014 11:13 AM
vtecsi00
Mar 5, 2008 12:35 PM
rbanke
Sep 12, 2006 12:13 AM
gftgrill
Oct 27, 2005 12:10 PM
simike
Oct 13, 2005 02:17 PM
