overflow bottle cap blowing off....
Old May 1, 2009 | 08:11 PM
jhammond_82's Avatar
Reject Papi
Default overflow bottle cap blowing off....
just got the teg today. its a 91 coupe, gs. 158,xxx miles on it. drove about 100 mile round trip in it, and the cap and hose in the overflow bottle blew out. twice. i didn't lose any coolant, just what was in the little hose, and no overheating at all. why would the overflow bottle be able to build that much pressure? from where? any help would be appreciated.
Old May 1, 2009 | 08:28 PM
jdm_bones's Avatar
Default Re: overflow bottle cap blowing off....
You might have a bad radiator cap, there is a valve on there that is suppose to release pressure, that's why they are maked whith either 0.9 or 1.1 on them, if that valve goes bad then you build up to much pressure, just be glad it wasn't a hose or something else...Go get you a new one!
Old May 1, 2009 | 08:34 PM
Ahknodd's Avatar
I would check your cap first, but I had my head gasket starting to blow do that same thing. I finally blew it completely and then it made sense why the coolant bottle was doing that. Do a quick compression test or if you have the tool and compressed air do a leak down test and see if you get bubbles in your coolant.
Worth a shot. Good luck.
Old May 3, 2009 | 07:29 PM
Reject Papi
haha! changed the radiator cap with one of those vent ones, and it fixed it, thanks guys!
civic_dork
Apr 24, 2019 04:01 PM
alvinahmed
Sep 16, 2012 09:32 AM
gurlugotmilk
Honda S2000
Feb 23, 2009 08:26 AM
CRXdan
Sep 18, 2008 03:23 PM
mickey513
Dec 20, 2004 11:21 AM
