Car shakes
Old May 1, 2009 | 05:41 PM
CompanyFlow's Avatar
Default Car shakes
My car shakes occasionally when going lower than 1500 RPM, but only at a certain point. Sometimes the pedal will only come back a little bit as well and I feel like there is air in the system. I have bled it TWICE and I still have the same problem. Any suggestions?
Old May 5, 2009 | 04:20 PM
Default Re: Car shakes
So I bled it again and it still does it. Its rare, but it still happens, and its completely random as well. Could it be a faulty slave cylinder?
Old May 5, 2009 | 05:05 PM
DC-2guy's Avatar
what rotors and pads are you running?
Old May 5, 2009 | 09:06 PM
Its a drivetrain issue. It has nothing to do with my brakes. It shakes as if I put the car in gear and just let it coast until it died, but at a lot higher RPM. It only does this from 1500 rpm until around 800rpm.
Old May 6, 2009 | 07:03 AM
mouab18c1's Avatar
shakes on acceleration? check axles tire pressure alignment. note that axles can be bad even without a torn boot or clicking noise
Old May 6, 2009 | 01:03 PM
Shakes on deceleration, and when this is happening, I'm also experiencing roughness engaging and disengaging the clutch. When I turn the car off, it goes away.
DougNuts
Jun 24, 2007 12:40 PM
bigdgsr
Sep 1, 2006 11:53 AM
dubzz24
10
Apr 3, 2005 05:06 PM
TypeR Freak
Feb 19, 2003 09:29 AM
Veil_Side_
Feb 3, 2002 07:11 AM
