trip out on this..
Old May 1, 2009 | 04:59 PM
dstah's Avatar
Default trip out on this..
today i was plugging in my spare ecu and i found this... anyone know whats the wires connected to another wires for? its like someone spliced wires and used electrical tape to connected 2 or more wires together.
its a brown/black wire from the biggest plug that is tapped into a all white wire from the little blue plug. then on the medium plug some green,yellow, blue wire is tapped into an unknown wire.
dstah's Avatar
Default Re: trip out on this..
anyone know why someone would do this? oh yeah and forgot, its an obd2.
Old May 1, 2009 | 07:02 PM
rick_rabies's Avatar
I'm not Rick!
we could tell by the blue plug its obd2, does it run fine though? why are you switching ecus? is a gsr motor in there. vtec wired?
Old May 1, 2009 | 08:07 PM
dstah's Avatar
it runs fine, i'm just curious whys it like that
Old May 1, 2009 | 08:41 PM
boostedb20z's Avatar
if you have a swap like b18 or such and its obd1 or 0 then its the ckp cross over thing to make it run right
Old May 1, 2009 | 08:43 PM
dstah's Avatar
nope, my motor is an original obd2
Old May 1, 2009 | 08:46 PM
turbo97coupe's Avatar
the only two reasons i know of to tap wires into each , is as listed above ^^ and then you also bypass the vtec pressure switch by bridging two wires. but the colors you listed don't match for a pressure sensor bypass so it must be the other .
Old May 1, 2009 | 08:57 PM
dstah's Avatar
i'll get better pics asap
Old May 2, 2009 | 12:37 AM
fastrxu's Avatar
you mean ckf (crank case fluctuator) that's found in the oil pump of obd2 usdm motors
all jdm motors and usdm obd1 and 2 motors don't have that
that's what I am guessing
Old May 4, 2009 | 04:57 PM
Gofmf's Avatar
My eg harness looks the same, don't know why it was done but the car runs fine like that.
bad71chevy
May 14, 2013 06:38 AM
dstah
Engine Management and Tuning
May 2, 2009 10:13 PM
TeamDOHCside
Dec 25, 2003 09:46 PM
